Who runs rear brake ducts?
First off, I know we have a brake/suspension section, but I thought this question would be more appropriate here. Second, I already googled what seems like something that may have been discussed and beat to death 100 times, but I wasn't able to find anything too colorful like the front duct discussions.
So, who runs rear brake ducts? For those who do, do you see any significant gains? And for those who don't, do you notice accelerated rear pad loss?
I'm about to create ducting for my front pads, and was wondering if I should bother doing the same for the rears.
Thanks.
Thanks.
if you have the time, it's likely worth it for saving your rear wheel bearings more so than for pad/rotor life.
https://www.s2ki.com/s2000/topic/949...brake-ducting/
My non ducted fronts were lasting me about 3 weekends or 6 track days. My rears were lasting at least through 2 front pads. But I basically swap them out every other time I do fronts. Once I ducted the front, I got almost 1:1 wear ratio between front to rear it's about. Also I didn't bother ducting the rear since it's not a vented rotor I figure I can't even pump the air into the center for the veins to pump out so what's the point of having only half the rotor cooled
Sent from my iPhone using Tapatalk
I burn through pads pretty fast. Before ducting, I was getting about 3 days out of a set of pads all the way around. After front ducts, I was getting about 5 days on fronts and 3 or 4 on rears. I recently added rear ducts and only have one day since then but just based on that one day, it looks like the rear pads will last longer. Compared to front ducting the rears are super easy to add so I would suggest to just do it.
Since I have been tracking on the same rear pads and rotors for years, I didn't think I needed rear ducting.
After seeing how much it is going to cost me to replace my bearings and hubs, I definitely think I need rear ducting.
I think I'm gonna experiment with a variety of the "ghetto duct" that was posted a while back.
Depends on the track/tracks being driven. I went to Gateway in St. Louis this year and then measured my pad wear afterwards. There was extremely low wear from that event. I'm sure if that's the only track I ran, I could have pads last a very long time. However, other tracks in my area are much harder on brakes so they more than make up for running at Gateway.
