me vs evo
Originally Posted by HwangTKD,Jul 14 2005, 07:56 AM
1) A few weeks? haha! i've seem differences of 10-20 whp from afternoon runs to evening runs! - OFF TOPIC
2) I've planned my mods carefully and have been running a $200 flash for 50K miles! so for me, it's worth it. - OFF TOPIC
3) Again you are avoiding the MAIN issue by addressing other aspects of this arugment, YOU ARE WRONG: There is a significant difference b/w the 03/04's and the 05's, THERE IS MORE THAN A 9 HP DIFFERENCE! - TOPIC
4) I assumed that you werent quite modded b/c this argument was based on STOCK s2000's BEATING stock 03-04 evo's at highway speeds......then you come in here for some unknown reason and start talking junk about killing s2000's (which tends to lead people to believe that you are near stock). Obviously a modded evo will take a stock s2000, it doesnt take a genius to understand that.
In conclusion, you are wrong!
Bobby
Bobby
you've been running a $200 flash and upgrading at the same time? Well then you arent getting the power you should be. You will have to spend $200 again to get the full potential.
i believe that there is a small difference between the two cars, but you are exaggerating the difference.
and thats what you get for assuming.
Originally Posted by evildylan,Jul 14 2005, 06:03 AM
you've seen that type of variance because you run on a shitty dyno i guess.
Bottom line you are wrong.
its obviously not a consistent dyno.
bottom line is you can't read, i said theres not much of a difference and theres NOT. Maybe the 05 is easier to get consistent times out of but 13.2 @ 102 is a fairly common time even for the 03s. if there truly was a 20-30 wh difference we would be seeing more and more 12 second stock evos. Granted there have been a few, but there have been some stock 12 second 03's as well. at the low 13 second area 20-30 whp is enough to reduce the time by 2-3 tenths. However they are running similar times.
you are saying the difference is huge when clearly it is not.
So in conclusion:
1) All the professional tuners on evom are wrong about the 10.5 hotside (including the likes of dynoflash, werks, vishnu) - you obviously have much more experience than them and can tune better to boot.
2) The dynos that have shown the differences in the current and ealier evos really dont show a 20-30 whp difference are flawed and there really only is a 9 hp difference (even though you use the same type of dyno).
You win
Good luck with your car!
Bobby
Originally Posted by Errelevant,Jul 14 2005, 09:57 AM
i think my 02 stock s2k ran a decent time of 14.4 in 90degree weather...I've seen as low 15 something so i don't think 14.4 is that bad of time
Originally Posted by Wisconsin S2k,Jul 14 2005, 12:09 PM
the slowest time I ever ran in my stock S2000 was a 14.3 in 90 degree weather. and that was with a missed 1-2 shift.
