New 335 on the freeway.
Originally Posted by versionJDM,Feb 1 2007, 05:49 PM
Looks really good man.
I would however suggest a tune. You get kinda lean up-top and are a bit rich down low.
Maybe S2K's like to run rich down low to help with tq, I dont know. 13.9 and 13.5 DO sound kinda lean though.
Is this just my ignorance in AP2's and the A/F's they like or what?
EDIT:
Did you go to vegas and get his friend to do that dyno run for you
EDIT:
EDIT:
EDIT:
stock AFRs run in the low to mid 12's.
Originally Posted by versionJDM,Feb 1 2007, 06:18 PM
i am tuned. i think you've confused AFR values. the higher the number the leaner the AFR mixture is. the lower the numerical value the richer the mixture. 13.9 is VERY lean by S2K standards, but my motor seem to like it just fine.
Originally Posted by N/Apower,Feb 1 2007, 06:22 PM
no, not confused. Some motors like to run rich as it helps with tq in some situations. I saw that you were as rich as 12.5 or less down low and as lean as 13.9 on one of your runs up top. I know you make good hp with that 13.9:1, but you are REALLY risking that motor imho. What were the KR values with 13.9:1?
Originally Posted by versionJDM,Feb 1 2007, 06:25 PM
i dunno, i only kept this sheet from the dyno. honestly it runs like a champ at 13.9. no detonation, knock, nothing. some motors like the lean. i think it helps that i always run the same fuel in it, chevron 93, keep the motor running consistant.
Originally Posted by N/Apower,Feb 1 2007, 06:27 PM
who knows, maybe your internal dimensions are SOMEWHAT different for some reason. Maybe you have ZERO carbon on top of you pistons. I dunno though man. 13.9 on a high rpm, high compression motor is asking for it imho.
Originally Posted by versionJDM,Feb 1 2007, 06:32 PM
its been running at 13.6:1+ for about a year now and shes still strong.
