S2000 Street Encounters Stories of on-the-road exploits and encounters.
VR4 and Stealths
Old Mar 10, 2003 | 12:49 PM
  #41
Z06-KILLR's Avatar
[QUOTE]Originally posted by DJAuggie
[B]
I checked around and he was in the 11's with the following:
K&N Intake, $100
MBC - $5 MBC from home depot air line fitting valves
ATR DP - $315
Gutted precats - $20 for a polishing wheel and a paddle wheel
$5 Tbolt clamp for stock Y pipe.
Used 1gen AFC, old knob style $140
6 DSM 450 injectors
Old Mar 10, 2003 | 12:55 PM
  #42
DJAuggie's Avatar
Originally posted by Z06-KILLR
It thought the stock intercoolers where not efficient when raising the boost ...someone needs to sell these 100hp packages for $ 1,999 on the web!!!!
um. Personally, I am not sure. My car is stock at 12PSI and I raise it to 15PSI when racing with stock fuel everything.
I wouldn't say it's a package. The guy bought a $5 BC, $5 Y-pipe because of high boost, used AFC, and used turbos I dunno, I spent much more on the same things but it works. He has many timeslips and videos as he put these mods on and dropped from mid 12s and into the 11s.
Old Mar 10, 2003 | 01:21 PM
  #43
Z06-KILLR's Avatar
What I was trying to say is that someone NEEDS to put these packages together (w/o the AFC/Turbo) and start marketing the heck of them!!
Old Mar 10, 2003 | 07:07 PM
  #44
xpander4's Avatar
Hmm. I don't mean to speak for HellBringer but unless these brothers have serious mods, they will not stand a chance against his VR4. It is completely badass for a car with a few mods.
CJB80 is making 420 - 430rwhp in his s2000 which weighs in about 2,700 lbs. Soon he will be making over 500rwhp. This combined with a nice final drive will put him in the 10s. I wouldn't be so quick to say the s2000 wouldn't stand a chance because it would take alot more than 500rwhp in a Vr4 to come close to the power:weight ratio of the much lighter S2000. Assuming the Vr4 weighs in at 3,500 lbs(could be wrong here) the VR4 would need 560rwhp to match the power:weight ratio of an S2000 with 425rwhp which is what CJB80 is at now. His car also has about the most aggressive gearing possible so the VR4 would also need a nice set of aftermarket gears as well to go along with this HP figure. When CJB80 takes it to 500rwhp the VR4 would now need 640whp plus the appropriate gearing. This is all based on a pull-on race obviously, the AWD will help the VR4 greatly off the line, but power for power those are the real numbers.
Old Mar 11, 2003 | 05:34 AM
  #45
DJAuggie's Avatar
Oh, well I don't want a $5 dollar Ypipe on my car There's just soo many modifications that can do wonders to cars that most people don't know about including myself. I hear bits and pieces and never know what to do but make small changes that I know are OK. Like fuel-pump hot wire and stuff like that are taken for granted as effective cheap mods.
-Shawn
Old Mar 11, 2003 | 05:35 AM
  #46
DJAuggie's Avatar
[QUOTE]Originally posted by xpander4
[B]
Old Mar 11, 2003 | 05:44 AM
  #47
Z06-KILLR's Avatar
[B]
Old Mar 11, 2003 | 06:29 AM
  #48
DJAuggie's Avatar
don't forget about traction....the S2000 will hurt tremendously trying to put that power to the ground...not so much the case of the pig4!
Taking sides are we?
Old Mar 11, 2003 | 10:56 PM
  #49
xpander4's Avatar
not with 315 sized drag radials in the rear.....probably not as bad as you think. Plus i defnitely didn't "forget about traction".....i *speciifcally* said the Vr4 had the advantage due to AWD, it was the very last point i made in my post.
Old Mar 11, 2003 | 11:09 PM
  #50
Z06-KILLR's Avatar
[B]
