04 Console Sliding Door Sticking
Old Nov 13, 2005 | 08:20 AM
dknightx's Avatar
Default 04 Console Sliding Door Sticking
I removed (actually, just raised up about 6 inches) the center console in my 2004 S2000 to allow me to pull the radio. After snapping it back in, my sliding cupholder cover doesn't retract the way it used to. It moves a couple of inches slowly and then stops. I can manually pull it back all the way but it clearly feels as if too much pressure is required.
I seem to recall others complaining about this issue in the past, but the S2KI search is broken now and I can't find the posts. Is there something simple I should look for to fix this? I removed the console again and looked underneath but didn't see anything obvious.
Thanks in advance,
-Dave
Old Nov 13, 2005 | 05:16 PM
Saki GT's Avatar
There's a center snap you likely didn't push in when you replaced the piece. Push down on the elbow rest and it should snap in and let the door slide easier.
40watts
Feb 8, 2009 12:24 PM
cullywoo
Mar 2, 2007 03:24 AM
nearwater4me
Feb 20, 2007 07:47 PM
s4play
Feb 23, 2006 08:30 PM
oatnet
20
Oct 20, 2004 08:04 AM
