04+ centre console removal problems
Old Mar 1, 2007 | 03:29 AM
cullywoo's Avatar
Default 04+ centre console removal problems
Hi guys,
Just seeing if ayone out there could help. After I replaced the headunit in my 05 S- the sliding door on the centre console no longer slid back smoothly - it sort of got stuck half way. I'm not sure if by lifting the centre console up to put the radio in I bent something.
I now have an 07 S and am about to replace the headunit on this. Anyone got any ideas where I went wrong last time - I don't want to make the same mistake this time.
cheers
Old Mar 1, 2007 | 04:40 AM
AlX Boi's Avatar
You could have spilled something and it ended up inside the console. I spilled coffee once and took the center plate to pieces just to wash.
Old Mar 1, 2007 | 05:13 AM
cullywoo's Avatar
I don't think so. It worked perfectly up to the point when I pulled up the centre console and then when I put it back its nice smooth action on opening was lost.
Old Mar 2, 2007 | 03:24 AM
AlX Boi's Avatar
Oooooh. I know exactly what you did. It happened when I removed the cup holder to clean. The door works via a spool with a thin metal piece spun around it. When I took it off, the metal piece uncurled off the spool and remained curled, but the door didn't have an automatic effect. I pulled the string back into the spool and everything was fine. It's very simple. Nothing to worry about.
mirabileboy
Apr 6, 2023 10:16 AM
40watts
Feb 8, 2009 12:24 PM
nearwater4me
Feb 20, 2007 07:47 PM
dknightx
Nov 13, 2005 05:16 PM
NECurve
Dec 26, 2004 04:59 PM
