Center console door "sticks"
Old Jan 21, 2009 | 02:09 PM
40watts's Avatar
Default Center console door "sticks"
The other day I removed my center console to remove/install my radio door on my '04, now the center console compartment slider door won't open by itself anymore.
It seems to stick or to be off track. I spent several hours trying to fix it. I had the whole console disassembled and got it slide open just fine but every time I screwed the cupholder compartment back on the door mechanism bracket I got the same problem.
Anyone have any ideas?
Thanks,
Brent
Old Jan 21, 2009 | 03:29 PM
starchland's Avatar
Im confused as to why you removed your console to remove your radio door? Anyways, which door are you referring to? The radio door has a little spring and if its not in the correct slot it wont recoil properly. The centre console compartment door is kinda sticky, mine is like that too and I cant figure it out. I only know that when I do it slowly its fine and if open or close it after waiting for a few seconds its fine.
Old Jan 21, 2009 | 04:50 PM
CKit's Avatar
Usually "center console" refers to the key locked box with the secret compartment on top.
Do you mean the cup holder by the gearshift?
Old Jan 21, 2009 | 05:04 PM
40watts's Avatar
Sorry bout the confusion, I'm referring to the cup holder sliding door. I had to remove the panel to reseat my radio door panel.
Old Jan 21, 2009 | 06:36 PM
JetBlackS2000's Avatar
Most likely coffee spill build up. lol
Old Jan 21, 2009 | 08:06 PM
Saki GT's Avatar
Assuming it works off the car, make sure you properly secure it to the car - there's a center nub you have to make sure is in or the door will not open smoothly - most people snap in the sides fine but forget to firmly push the center down as well.
Old Jan 22, 2009 | 05:50 AM
midnightmethane's Avatar
my door starting sticking a little lately and I decided to use a little WD-40 in the slots...opens smoothly now
Old Feb 8, 2009 | 12:24 PM
40watts's Avatar
It seems that when I removed the "cupholder panel" the door track was slightly bent. I gently bent it back on track, works like new again!
s4play
Feb 23, 2006 08:30 PM
dknightx
Nov 13, 2005 05:16 PM
mbongiovi
Nov 10, 2004 07:35 PM
mbongiovi
Nov 6, 2004 02:29 PM
oatnet
20
Oct 20, 2004 08:04 AM
