04 redline ?
Originally posted by pwalker
Redline:
8,000 rpm - 2.2 engine
8,800 rpm - 2.0 engine
Fuel cutoff:
8,200 rpm - 2.2 engine
9,000 rpm - 2.0 engine
Redline:
Fuel cutoff:
3ngin33r1, is your graph generated from some sort of data logger using ODB-II port? If so, do you know what the sampling rate was when this run to fuel cut-off took place? My guess is that the sampling rate of the ODB-II port and/or the data logger may not be high enough to give an accurate picture of the exact RPM at which fuel cut-off occur.
