04 redline ?
Old Oct 29, 2003 | 08:04 PM
t.c.'s Avatar
Default 04 redline ?
Is it true that the 04 redline is 8000 rpm ?
Thanks
Old Oct 29, 2003 | 08:11 PM
mrhands0me's Avatar
uhm yes... check out the other million post buddy
Old Oct 29, 2003 | 08:20 PM
AusS2000's Avatar
Only on the F22C powered S's.
Some markets (US and possibly others) the engine is enlarged to 2.2 L and the red line reduced to 8000. JDM (and possibly other) are stying at 2L and 9000 rpm.
Old Oct 29, 2003 | 09:04 PM
pwalker's Avatar
Redline:
8,000 rpm - 2.2 engine
8,800 rpm - 2.0 engine
Fuel cutoff:
8,200 rpm - 2.2 engine
9,000 rpm - 2.0 engine
Old Oct 29, 2003 | 09:27 PM
3ngin33r1's Avatar
I think your fuel cutoff is backwards...
Old Oct 30, 2003 | 04:51 AM
STL's Avatar
STL
Originally posted by pwalker
Redline:
Fuel cutoff:
That is odd, based on various sources the general consus around here (previously to the 2.2 release) has always been that the 2.0 has a redline of 9,000 and a fuel cut-off of 9,200-9,3000. I have seen where some early Honda docs said a redline of 8,900 but I never seen it documented as low as 8,800.
Old Oct 30, 2003 | 09:10 AM
3ngin33r1's Avatar
Old Oct 30, 2003 | 11:20 AM
RedondoS2K's Avatar
3ngin33r1, is your graph generated from some sort of data logger using ODB-II port? If so, do you know what the sampling rate was when this run to fuel cut-off took place? My guess is that the sampling rate of the ODB-II port and/or the data logger may not be high enough to give an accurate picture of the exact RPM at which fuel cut-off occur.
Old Oct 30, 2003 | 11:23 AM
3ngin33r1's Avatar
I'll redo the test and hold my RPM just before cutoff to get a better idea, but yes, it's an ODB-II data logger.
Old Oct 30, 2003 | 11:48 AM
Luis's Avatar
Fuel cutoff on mine occurs beyond 9.2krpm as logged by a SPA digital rev gauge.
