1-2 grind for 2001 s2000's?
Old Mar 14, 2001 | 08:23 PM
  #31
y2ks2k's Avatar
Darn, sorry for chimming in to late here but my 2001 had its clutch disk replacement at 600 miles.
Old Mar 14, 2001 | 08:48 PM
  #32
gregstevens's Avatar
Banned
The grind is more prevalent when the box is hot... by cdelena
I just thought this was a choice quote by Mr D'Elena...
How true it is...my man, how true it is...
Old Mar 14, 2001 | 09:22 PM
  #33
VisualEchos's Avatar
I have it on good authority that the "grind problem" was fixed within the '00 MY. However, that does not mean that some '01s will not experience a similar problem, just not the EXACT problem.
The throw on this shifter is quite short as mentioned before, and the clutch must absolutely be to the carpet. This is a design flaw in my opinion, it leaves little if any room for error.
Old Mar 14, 2001 | 09:46 PM
  #34
malachi's Avatar
please define "good authority" in this case, and carefully read some of the posts above. i know i'm starting to:
a - doubt it WAS fixed, and
b - get rather irritated that folks assume that it has to be driver error FIRST rather than trusting that maybe, just maybe, we DO know how to drive and DO know the difference between screwing up a shift and something unexpected and unexplained.
if your "good authority" is believable (and preferably can be contacted, quoted or the like) than i'll have less distrust of the idea.
However...
it strikes me that this is a classic application of Occam's Razor. here is the data:
a - a car has a mechanical problem (acknowledged by the manufacturer).
b - the same model of car (but of a different year) exhibits identical symptoms to the symptoms that indicated the mechanical problem above.
there are three possible explanations:
a - the second car has a different problem that coincidentally exhibits the exact same symptoms as the first car.
b - the data is faulty and there is no actual problem with the second car.
c - the second car has the same problem as the first car.
the most simple, direct and logical explanation is A.
Old Mar 15, 2001 | 03:21 AM
  #35
dbarnes's Avatar
Jay Li,
I went 12,500 miles without grinding any gears. Now at 12,650 miles I have experienced five grinds while shifting from 2nd to 3rd.
-Donnie
Old Mar 15, 2001 | 03:57 AM
  #36
cdelena's Avatar
[QUOTE]Originally posted by S2Kguy
[B]I have it on good authority that the "grind problem" was fixed within the '00 MY.
Old Mar 15, 2001 | 04:47 AM
  #37
Barry in Wyoming's Avatar
1,300 miles, all in cool Wyoming. Never a grind. Buttery smooth, delicious shifting so far.
Barry
Old Mar 15, 2001 | 06:06 AM
  #38
RodneyK's Avatar
ROTFL! That is dead on...
Old Mar 15, 2001 | 06:08 AM
  #39
cmnsnse's Avatar
Maybe there is a BioFeedback sensor in the shifter knob, and when you are trying to show off, it grinds . . .
That's what happens to me, smooth shifting all day, then when you need it, GGGRRRRRRRRRRRR
maybe its not just a stacking tolerance? but also a design flaw? it is the only *Triple* cone syncro in there.
Mines a '00, sorry for butt'n' in to the '01 stuff
SiK182
Jun 22, 2001 01:40 PM
JT-KGY
Apr 28, 2001 08:22 AM
4IGS2000
Mar 22, 2001 10:32 AM
Y2K1S2K
Dec 18, 2000 09:59 AM
pfb
Dec 9, 2000 09:09 PM
