1 - 2 grind
Old Oct 19, 2001 | 07:58 AM
AlexM's Avatar
Default 1 - 2 grind
For those of you familiar with this subject, how soon after getting the car does it begin to occur, and how often do you experience it. I believe it is beginning to happen to me (MY2001, 2500mi). It does not occur often, maybe once or twice a week, and it only happens at or near redline. So what I am trying to figure out is whether I am getting sloppy with my shifting, or do I need the TSB.
Old Oct 19, 2001 | 08:00 AM
Phantom's Avatar
AlexM,
When I had the grind...it would do it at regular RPM's also...like 3,500 or something.
Drive around a bit more...and if it happens again...bring the sucker in.
Old Oct 19, 2001 | 08:15 AM
yu888's Avatar
The TSB grind happens all over the rpm spectrum. I personally account for the high rev grinds as me getting sloppy with the clutch. After I got the TSB done though, no more randome grinds...only ones that are my own fault. good luck with yours
Old Oct 19, 2001 | 08:35 AM
cdelena's Avatar
My experience both before and after the TSB work is that the 1-2 grind occurs when the gearbox is hot. Most of the time it happens at 4
Old Oct 19, 2001 | 03:28 PM
scottrnelson's Avatar
When I when on my two week trip last May, it became quite obvious that the grind happens more in hot weather than in cool weather. I just had my transmission repaired last week for a bent shift fork on 5th gear and they installed the fix for 2nd gear while they had the transmission out. It will probably be six months before I find out for sure if the 2nd gear grind problem is really fixed, since the weather is cooling off.
Old Oct 22, 2001 | 02:25 PM
SUis1's Avatar
cdelena:I have the same problem. I had the TSB done Twice, and just got done with the District manager (see my clutch post). I still have an open file with Honda and will begin the fight. But...I'm wondering if this is something we need to gather data on like was done for the 4cyc failure and approach Honda as a group. One thing I know for sure is every grind hurts the Syncro rings and they don't heal themselves.....
Old Oct 22, 2001 | 03:05 PM
cdelena's Avatar
[QUOTE]Originally posted by SUis1
[B]cdelena:I have the same problem. I had the TSB done Twice, and just got done with the District manager (see my clutch post). I still have an open file with Honda and will begin the fight. But...I'm wondering if this is something we need to gather data on like was done for the
Old Oct 22, 2001 | 06:13 PM
SUis1's Avatar
Check my Poll
s2kmtl
May 29, 2001 03:34 PM
RandyP
Apr 25, 2001 03:19 AM
Kevin_in_Austin
Feb 26, 2001 03:54 PM
Dorian Gray
Jan 31, 2001 05:10 PM
