12 second S2K ALL MOTOR?
Old May 3, 2004 | 09:49 PM
  #31
devilchrist's Avatar
[QUOTE]Originally posted by soundzero
I truly feel bad for those who thinks S2000 is a drag car.
It is precision tool that is designed to carve corners and run faster than many competitor around the track.
Simple as that.
Old May 4, 2004 | 07:35 AM
  #32
spikez513's Avatar
Anybody know what's the most weight that has been stripped from this car?
Old May 4, 2004 | 01:49 PM
  #33
terd ferguson's Avatar
[QUOTE]Originally posted by SanchothePanda
Mandatory Post: The s2k is not I repeat not a drag car. It was never designed for it, and it does not excel at it in stock form.
The most probable way to get a 12 sec car is to remove massive wieght. The S2000 is highly tuned from the factory and doesn't gain much in mods. Even Spoon racing motors top out at around 300hp IIRC. Dropping pounds = cheaper and easier to gain seconds than engine mods.
The reason FF N/A Honda's can run 12 seconds is because they're generally hatchback civics, CRX's, etc. In other words, they're small, which means they're light, ranging from 1900-2200lb's (guesstimate). 200 Horsepower pushing 2000 lb's is going to be faster than 240 hp pushing 2800 lb's...(QUOTE)
My ep3(02 civic si) hatch weighed 2800 lbs.
Old May 4, 2004 | 02:07 PM
  #34
blues2k3's Avatar
"Horsepower Results - 1/4 Mile Method
Your honda s2000 weighs about 2500 pounds and can complete a 1/4 mile in about 12.5 seconds. That means that you've got about 258.05 HP at the wheels, and about 303.58 HP at the flywheel." this is what I got off the quarter mile calculator. Getting that 260 at the wheels NA is a bit tough but not impossible. I believe someone was up to about 236 at the wheels NA. Also the diff on this car is a bit difficult to perform.
Old Feb 20, 2011 | 02:37 AM
  #35
spo001's Avatar
Hi Guys.
Just wanted to make a point here!
I don t agree with you that an S2000 is not good for drag racing, it is all in the set up.
I guess that any production car was not designed to be a Drag car . I agree that our cars are designed for track use not for drag , if you take a look at S2king on You Tube then you can see what an S2k can do
So to come to a conclusion , yesterday i was at the track and i managed to hit 12.88 seconds @109.90mph .. 60 ft / 2.00 with my NA S2000
Below pls find my mods:
K24crank which with this mode my car is 2342cc
H22 Rods
H22 Pistons
4.44 J'S Final Drive
Spoon Lightened flywheel
Spoon Clutch kit
HKS 4-1 Header
J's super circuit
Trust Short ram air intake
Hondata K-Pro
RC 650cc injectors
Hondata Manifold Inlet gasket .
Bf Goodrich Drag radials
Power 276hp @190FT Torque.
In my opinion i can lower the time cause i should get better 60ft times.
Please let me now if you require any other information.
In my opinion with a better 60ft time i can manage to
I think i
Old Feb 20, 2011 | 01:43 PM
  #36
BumbleBee01's Avatar
^^^ add ITBs please
Old Feb 20, 2011 | 01:57 PM
  #37
suzuka-blue-s2k's Avatar
Originally Posted by spo001,Feb 20 2011, 05:37 AM
Hi Guys.
H22 Rods
H22 Pistons
Spoon Clutch kit
HKS 4-1 Header
J's super circuit
Hondata K-Pro
RC 650cc injectors
I think i
I was coming in here thinking I was going to tell a newb to search, but that was a nice bump.
Do you have any of the time slips that you can post?
Old Feb 20, 2011 | 03:48 PM
  #38
IAmTheRealAsif's Avatar
You have to pick good parts. Not a 60mm exhaust. lol
But... On the 06+ I would do this:
CAI
PLM header
3 inch exhaust with/tp
Flashpro tune
4.57 gears
Slicks
Mild weight reduction
Honestly, I have never seen anybody with that set up go to a 1/4 mile. I think a 12 second pass is doable. My friend ran a 13.6 with just a 70mm and tp.
Old Feb 20, 2011 | 04:53 PM
  #39
J-GO's Avatar
S2000 not a good drag car. Hehe
Old Feb 20, 2011 | 06:36 PM
  #40
krazik's Avatar
Administrator
yeah I sorta thought 276hp was a bit low for a motor that big. Tho I don't know what type of dyno that was measured on. but I've seen 2.2L's making over 260hp
