170 miles Only on a full tank
Old Sep 5, 2007 | 03:53 AM
agent's Avatar
i get ~350km er tank if i'm agressive in the city and 500+ if i cruise a lot on the highways.. there's definetly something wrong with your S
Old Sep 5, 2007 | 04:18 AM
deathsled's Avatar
If you know you have a bad o2 sensor then thats probably the issue, the computer is probably having a hell of a time keeping an optimum AFR under closed loop operation and you're probably running rich as hell constantly. How do your exhaust tips look? You're probably also zapping your cat if its not dead already.
Old Sep 5, 2007 | 04:21 AM
fastgsx's Avatar
I also think that the o2 sensor is the problem.
Old Sep 5, 2007 | 04:24 AM
Tsuchiya's Avatar
I used to have a bad primary O2 in another Honda. It ran so rich that a cat would last less than a week on it. Went through 3 cats before I just gutted the thing
Old Sep 5, 2007 | 09:10 AM
melonheadr6's Avatar
Also, is your air filter clean? I changed mine at 30k miles and it helped my MPG dramatically.
Old Sep 5, 2007 | 09:22 AM
__redruM's Avatar
You've already pointed out some pretty obvious causes, get them fixed. A bad O2 sensor will definately contribute to bad mileage, and so will a clogged cat. While you at it, do some of the stuff mentioned above. Air Filter, Tire Pressure, etc.
If all that fails then, try getting opinions on the internet...
Old Sep 5, 2007 | 09:38 AM
S2kInVaSi0n's Avatar
max i had ran a full tank on my ap2 about 305 miles, till i hit up the gas station.i was like woww,but normally it'll probalby get 280 and up.
Old Sep 5, 2007 | 09:40 AM
GPMike's Avatar
Banned
Damn...you need to bring your car in for a full check up. I just hit 160 miles on half a tank....70% hwy/30% city.
Old Sep 5, 2007 | 09:56 AM
WashabiS2K's Avatar
i only hit 160 on my last fill up, but it was all city driving.. i am not sure if the s/c has much to do with it? my friends with sc'd S's have way better mileage than i do.. my average mileage per-tank is around 180 with mostly city driving. however, combined with highway, i think the max i hit was 250 miles on one tank.
Old Sep 5, 2007 | 12:10 PM
CKit's Avatar
Do you have a yellow box or other speedo / odo calibration device?
Your 160 miles might actually be 220 with the 18 inchers?
