2.2L Engine swap
Originally Posted by kitwetzler,Jan 27 2005, 06:40 PM
If you look at my dyno chart, it appears that Honda isn't telling the whole story... the power does indeed come on 500 or so RPMs sooner, but it also continues, my car made peak power exactly at redline
Just a thought......
Drive Safe,
Steve R.
Originally Posted by Warren J. Dew' date='Jan 27 2005, 09:57 PM
Do you know if the '02 was tweaked in any way? The mid range does not show the sag in torque around 5000 rpm that I've seen on other dyno charts. If you shift the lines using percentage of maximum rpm as the horizontal axis (so that both redline at the right end of the graph), the two power lines will lie almost on top of one another except at the very top end - without the difference in the mid range that is supposed to be the main difference between the engines. I wonder what's going on there.
No, you're actually incorrect about the shifting the lines, too. Look at the post VTEC power, not only does the 04 make more power, but it is more accessible. first gear goes by too quick but I'd expect that if we lined up these cars in second that the 04 would pull away pretty hard.
OK, I found an interesting article about piston speed for 04
according to this article
http://www.caranddriver.com/article.asp?se...article_id=7274
03's piston speed = 4906 feet per minute @ 8900 rpm
04's piston speed = 4761 feet per minute @ 8000 rpm
so in calculation
04 piston speed @ 9000 = ~5356 feet per minute
04 will have same piston speed as 03 when rpm is ~8244 rpm
04 @ 8500 rpm = ~5059 feet per minute
in conclusion 04 piston speed actually increased rather than decrease.
i dont think 04 engine w/ 9k redline will be so safe.
btw how's the project going?
so in calculation
Originally Posted by kitwetzler' date='Jan 28 2005, 01:02 AM
The 02 was bone stock.
Regarding the lines, I did say "except at the very top", right? The '05 at 7200 is about 200 horsepower on that graph, about the same as the '02 at 8000 rpm; in both cases that's about 10% below red line. It's only in that last 10% that the '05 makes more power while the '02's power flattens out then falls.
^ that would be relevant if the cars were geared to redline at the same speed. In fact, the 04/05 reaches the power earlier due to shorter gearing, which means it'll accelerate a lot quicker.
Hmmm,
I am very interested in seeing how this pans out. UL posted about buying a 2.2l short block for under 3k. That could be a sweet project, a 2.2l with an F20C head.
But I wouldn't do it if the redline dropped from 9k rpm.
stay tuned fellas
