2006 drive by wire question
Old Aug 3, 2010 | 11:57 AM
Alex S2000's Avatar
Default 2006 drive by wire question
Does the drive by wire system make the car less of a pure sports car? Is it less fun to drive, than say an 05? Is the throttle tip in to sudden? I test drove an 06, and didn't seem to notice anything. I haven't driven an 05. The reason I ask is that the Infiinti G35 throttle is very touchy. Hopefully my question makes since.
Old Aug 3, 2010 | 12:23 PM
Jumpman2k's Avatar
I can't say I noticed much of a difference between my '08 and my friend's '03 in terms of throttle response. Others may disagree. I will say I love my car and I don't think I've seen any complaints from other 08/09/CR owners about the throttle.
Old Aug 3, 2010 | 12:33 PM
03_BB_S2K's Avatar
i have cable throttle and personally i would prefer the drive by wire instead. My 07 honda fit has drive by and i notice a difference between the s2k and the honda fit in terms of throttle
Old Aug 3, 2010 | 01:32 PM
patinum's Avatar
I haven't noticed a difference, or at least much of a difference...except when I added Hondata, at which point it's been a nice improvement.
Old Aug 3, 2010 | 01:33 PM
spdracerut's Avatar
Every drive-by-wire system is different. It can be calibrated to all sorts of different throttle position vs. throttle plate openings for whatever conditions.
Nissan likes to calibrate it so that the initial throttle tip-in is really aggressive, so it feels really torque, like a typical domestic vehicle. If you turn off the traction/stability control, it completely changes the throttle mapping and makes it much less touchy.
I found this out when I had a G35 sedan that I tracked. With all the electric nannies on, the slightest throttle tip-in at the apex of a corner would cause the rear to swing wide. Then the stability control would kick in and apply the brakes to the rear wheels to bring it back in. After the first session, I had the rear brakes smoking pretty badly.
Turned off the stability control, and the throttle became much more linear, like a regular throttle cable. Made the car a lot easier to drive.
Uh, in short, it all depends on the calibration.
Old Aug 3, 2010 | 02:17 PM
seoulbro's Avatar
I can't seem to tell the difference especially when I have the VSA off. I can understand wanting a '05 or earlier models for pure driving experience with no computer aids.(although all you have to do is hold the button to turn the VSA off)
I hope I can get the Flashpro before the Evans Tuning meet.
Old Aug 3, 2010 | 02:47 PM
Alex S2000's Avatar
Thanks for the quick replies.
Old Aug 4, 2010 | 06:46 AM
TPhong's Avatar
The DBW isn't bad at all in the S2000 compared to the Civic Si, TSX, or newer RSX's. I'd worry more about the clutch delay valve and it prematurely wearing out the clutch.
Old Aug 4, 2010 | 07:10 AM
whiteflash's Avatar
I couldn't notice any DBW difference between my 06 and a 04 that I've driven. Throttle response feels identical.
TheHeggi
Mar 22, 2010 11:07 PM
hey32g
Sep 30, 2009 08:58 PM
macdaddies911
May 3, 2008 01:03 AM
pexcellence
Aug 8, 2006 01:57 PM
Lead_Foot
Nov 26, 2004 05:00 PM
