30k mile service
Old Sep 29, 2008 | 02:35 PM
hariku821's Avatar
Default 30k mile service
I called honda and they said it would be 400$.. Is their any way i can get around this? Im sure i can change the dif and trans fluid as well as motor oil.
Are the breaks hard to do? Also is the fluid going to be grossly expensive? Do i have to go through honda to get the fluid or is their a good brand you can pick up at the store or have shipped?
Also i hear that the stock break pads arent so great what would you guys recomend. The car will see the track 5 times max a year doing about 5-8 laps on a 1 mile track.
Is it worth 400 to have them do it?
Old Sep 29, 2008 | 02:37 PM
turbosix's Avatar
what are they including in the $400?
not to mention you might not need new pads right now or anything dude... you should check them before going out and buying new ones..
Old Sep 29, 2008 | 02:48 PM
hariku821's Avatar
Im not sure if the dif fluid or trans fluid has been changed i know for sure i want that changed as well as the oil. Pads could probably wait but i would like some better ones from what i have heard about the stock pads.
The guy on the phone just said dif fluid air filters oil and trans as well as an inspection. I know those inspections only cost 85$
Old Sep 29, 2008 | 02:54 PM
bumblebeeS2K's Avatar
is this car a dd? oem pads a far better than people think they are, plus going with any worthwhile aftermarket pads will force you to compromise between comfort, performance, etc., which sometimes isn't worth it on a dd that only sees five track days a year. a better solution would to buy a set of pads that only sees the track.
Old Sep 29, 2008 | 03:34 PM
turbosix's Avatar
is a weekend afternoon worth $400 to you?
Old Sep 29, 2008 | 03:36 PM
hariku821's Avatar
Nope thats why im wanting to do it myself it looks like their are diys on here for everything that needs to be done. I just wanted to make sure their wasn't something major that i couldn't do.
Old Sep 29, 2008 | 04:12 PM
AstroPhsx's Avatar
They will probably try to charge you over $200 for the 3 fluid changes. If you can do it yourself I def would, also you can get the pollen air filter, air filter, oil filter, transmission fluid, and brake pads for pretty cheap from http://www.handa-accessories.com/. If anything do the air filter and the pollen filter, will take you 5 mins and save you $$$
Old Sep 29, 2008 | 04:15 PM
S2KAYYY's Avatar
I did everything my self except the breaks.
good luck
Old Sep 29, 2008 | 04:33 PM
roflitzjinno's Avatar
most of these things are routine maintenance. diy is your best bet. and a little bit of poke this check if this is okay and all that bullshit.
bgoetz
May 8, 2017 08:20 AM
S2KNJ
Aug 2, 2007 10:55 AM
TypeRa
Dec 12, 2006 07:23 AM
Ks320
Aug 24, 2006 08:58 AM
WVtwisties
Sep 1, 2005 03:53 PM
