4.57
Old Jan 7, 2006 | 09:00 PM
andersayz's Avatar
Default 4.57
do the 4.57 gears help the s2000 in highway pulls or is it mostly from a dig? also will it affect the performance of the s2000 in a road course?
tia
Old Jan 7, 2006 | 10:05 PM
steven975's Avatar
it helps pretty much everywhere. Though potential top speed is lowered, actual top speed is probably the same (as you have more power at that specific MPH).
Old Jan 8, 2006 | 09:23 AM
cdelena's Avatar
You generally will be in different gears at different points on a road course as compared to stock gearing. Depending on the course it may help a little, hurt a little, or make no difference.
Old Jan 9, 2006 | 07:51 AM
Wisconsin S2k's Avatar
tia
the difference at higher speeds is not as noticeable as lower speed runs. that doesn't mean you won't pull. we charted it out once, and the geared S2000 will be faster at any race, EXCEPT if you START at 105mph roll. which the two will be about even.
if you start at 80mph, however, you'll pull the entire way to your top speed (about 155mph with 4.56 gears)
as for the road course, thus far I have found it helps tremendously, particularly because the low end "grunt" is increased. however, as stated, it could help, hurt, or make no difference depending on the road course.
Old Jan 9, 2006 | 08:41 AM
x s2k x's Avatar
How reliable is it? How much with install?
Old Jan 9, 2006 | 08:56 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Stronger than OEM gears.!!!
Old Jan 9, 2006 | 09:48 AM
x s2k x's Avatar
How much do you think it will run with install?
Old Jan 9, 2006 | 10:41 AM
www.ricks2k.com for current pricing. they can provide pre-installed gears in diffs. this install needs to be done by someone who is experienced in doing S2k gears.
Old Jan 9, 2006 | 11:27 AM
Aggv's Avatar
So if someone wanted a car to race mostly on the freeway(40-60mph) pulls. Would this gear setup be ideal?? or would the stock longer gears be best?
Old Jan 9, 2006 | 02:23 PM
even starting at 40-60mph pulls, the car with the 4.56 gears is going to be faster.
