5 Things that bug me about the S2000
Old Aug 5, 2016 | 04:15 PM
  #21
zeroptzero's Avatar
I'm average height. Below average weight :'(
Nothing about this car bugs me in terms of ergonomics. It fits me like a glove. The stereo is pretty bad, though, if I'm grasping for something to complain about. Bose option stereos in Miatas are better.
Edit: maybe the fact that they never thought to fix the stupid door lock situation in the 9 years the car was in production. Power locks. No power un-locks. I gotta reach over to the other side like a slave. MF'ing uncivilized.
I had that same complaint having to open the passenger door for the wifey all the time, but fortunately the modifry "free" fix made short work of this Honda oversight, no more reaching over with my fat ass.
Old Aug 5, 2016 | 05:25 PM
  #22
Hfreak's Avatar
You could always just press the unlock button on the FOB twice and unlock both doors, works for me.
Old Aug 5, 2016 | 05:31 PM
  #23
zeroptzero's Avatar
Originally Posted by Hfreak
Originally Posted by zeroptzero' timestamp='1470442535' post='24033331
[quote name='B serious' timestamp='1470439991' post='24033303']
[/quote]
I was referring to using the FOB from inside the car to unlock the passenger door while the car is running - Modifry has a fix to allow this. The default Honda setting disables the FOB while key is in ignition. What B Serious was complaining about was that you can lock both doors from inside the car by pushing the driver door lock, but you don't have the ability to open the locks electrically from inside the car.
Once you do the Modifry fix you can open both doors using the FOB from inside the car with the key in ignition, hence no reaching over to the passenger side to unlock. It also allows you to open the trunk using the FOB with key in ignition as a side benefit to the mod, so less reaching to the secret compartment and more convenient in case your console door is locked. Best free mod IMO.
Old Aug 5, 2016 | 05:36 PM
  #24
Hfreak's Avatar
That makes sense if you have an unplanned passenger, I just tell her to reach in and unlock it herself and get the WTH.
Old Aug 5, 2016 | 06:21 PM
  #25
haga888's Avatar
Passengers add weight. They can take the bus. Problem solved!
Old Aug 5, 2016 | 09:02 PM
  #26
AZS2KDancer's Avatar
Learn to adjust your mirrors. They should teach you that on your first track day. No need to turn your head. You can find a video online.
Two 22" carrying suitcases fit easily into the trunk. And there's room on each side. That's WITH the tool kit and tray in place. Two people can travel easily for as long as you want to.
You just got this car. You have a lot to learn.
Old Aug 5, 2016 | 10:06 PM
  #27
S2ALEXIS's Avatar
Definitely the easiest/quickest weight reduction lol
Old Aug 5, 2016 | 10:08 PM
  #28
BlakeNFR's Avatar
Originally Posted by S2ALEXIS
Originally Posted by BlakeKleinCalabrese' timestamp='1470436079' post='24033269
[quote name='S2ALEXIS' timestamp='1470434173' post='24033258']
[quote name='darcyw' timestamp='1470433648' post='24033248']
i like how tight it is- fat people don't.
trunk is fine for my needs- i usually just cut my victims up into little pieces and they just fit fine in the trunk.
Top down- no visibility problems but top up, yeah, the top has blind spots. But i have mad skills backing up so i can deal.
Gas is cheap- in fact, i encourage wanton waste of gas in the pursuit of speed.
I can't think of anything i don't like about it...maybe, that i don't own 2 of them and that honda stopped producing them. oh, and the stock stereo sucks.
But, since you asked.
darcy
Yeah, I also forgot to add that you can't put your top down while rolling lol
There's an easy fix for that, you gotta pull a plug that's located in "mexican border crossing" secret compartment.
I have a hardtop, so no visibility or noise issues. Ground clearance can be an issue on some parts of the road, but my MPG is around a solid 30mg when I actually keep it in 6th and not try to speed.
[/quote]
I've seen the plug thing. And I also want a hardtop, eventually I'll get one, I don't drive with my top down much. Do you keep your hardtop on all the time?
[/quote]
I've always keep the hardtop on. Winter or Summer. It's bolted on, the OEM latches are just as good as having a "free hardtop" sign on the window.
If you're trying to figure out your mileage, reset your trip after filling a full tank of gas. Once you go to fill it up again, divide the miles on the trip with how many gallons you filled up.
Example. 202.5 miles on trip when refilled. Car took 10.4 gallons. 202.5 miles / 10.4 gallons =19.47 MPG. The tank holds 12.9 gallons, I've never gotten past the last few gallons. Too paranoid.
  #29
S2ALEXIS's Avatar
I've had it for less than a year. Tried fitting a frame in the trunk. Didn't fit. Also a big suitcase. Not 22" didn't fit lol. And as for the mirrors, I have them adjusted properly. Just so used to looking over my shoulders that I do it regardless of which car I'm in.
Old Aug 5, 2016 | 10:11 PM
  #30
S2ALEXIS's Avatar
Originally Posted by S2ALEXIS' timestamp='1470438200' post='24033288
[quote name='BlakeKleinCalabrese' timestamp='1470436079' post='24033269']
darcy
[/quote]
[/quote]
[/quote]
I think that's what I did. It was when I just got the car though, so like I said, my foot was heavier lol. Gonna do it again this week. Thanks.
