ABS Light was on for a while~! Help~~
Old Aug 3, 2004 | 09:37 AM
AustinS2k2003's Avatar
I had the same problem a few weeks back - ABS light came on after I braked very hard one time, then went out when I turned the ignition off and back on. Hasn't shown up since so I figured it wasn't a big concern...
Old Aug 3, 2004 | 10:40 PM
Siepel's Avatar
Austin: If the ABS lamp comes on during hard braking, it most likely is the fuse to the ABS pump.
In Alex' and Jinuoppa's case: I'm thinking the ABS ECU fuse or perhaps the ABS relay is slightly loose and sometimes has a disconnection. It could also be one wheel sensor which has a disconnection. It's a little bit hard to tell. When the lamp is on again, but ABS still works (which IS possible) than there is a wheel sensor disconnect for sure.
Good luck!
Siepel
Passions
Mar 11, 2008 09:50 AM
kjs2000
Aug 28, 2005 08:26 AM
BurnNSensation
Jun 28, 2004 09:35 PM
wasabe
Jul 17, 2002 07:46 AM
ddelaros
Mar 15, 2002 04:07 PM
