Aligning headlights and bumper
Old Oct 30, 2003 | 10:53 AM
Mok's Avatar
Mok
Default Aligning headlights and bumper
Has anyone had problems aligning headlights and bumper?
I can't seem to get mine to fit just right.
The left headlight sticks out and the right one keeps pinching against the bumper...
Old Oct 30, 2003 | 11:30 AM
amongmany's Avatar
I had the same problem when replaced mine recently. I found that the best way to do it is to get all the bolts started loosely. From there you can kinda tighten the various points as needed to get the lights to sit right.
Old Oct 30, 2003 | 01:43 PM
Mok's Avatar
Mok
Thanks Munckee! I'll try that, but what a pain in the a**.
Old Oct 30, 2003 | 02:15 PM
amongmany's Avatar
Yeah, it is. Esp. if you've already bolted the bumper back on.
Old Oct 30, 2003 | 02:36 PM
Uncle Fester's Avatar
I recently had the passenger headlight replaced and now the fit and alignment isn't as good as it used to be. The weird thing is, is that it looks like they were able to replace the headlight housing without removing the bumper. I'm going to have to tackle it here soon and try to adjust fitment.
Old Oct 30, 2003 | 02:42 PM
amongmany's Avatar
I don't believe it's possible to replace a housing without removing the bumper. Maybe they just loosened the bumper and pulled it off one side, but even then it'd be tough to get to all the bolts and things holding the light in. There are about eight bolts that hold the headlight if I remember correctly, and you have to take a metal brace off to get to it.
Old Aug 18, 2006 | 04:57 PM
maxfior's Avatar
I thought that I would bring this thread back to life as I noticed tonight on my ride home that my passenger light was moving. When I did get home I noticed that the top portion of the light seems to be loose, as it can be pushed back into the fender. Are there bolts that came loose that just need re-tightening? Do I have to remove the front bumper to inspect? I've done to searching and this was the only thread that I've found pertaining to my situation.... Could someone please let me know what I should check / do? Thank you very much in advance!
Max
Old Aug 18, 2006 | 05:08 PM
ruexp67's Avatar
You have to remove the bumper and inspect.
Old Aug 18, 2006 | 06:33 PM
maxfior's Avatar
I'll give that a try. Is there a write up on how to take off the bumper, search gives me weird results with nothing definitive. I just want to make sure that I'm doing this properly... I have the tools I just need a place to start.... Thank you though! Any other help, links, etc. would be great. I think it might be time to buy the factory manual though. Thanks all!
M.
Old Aug 18, 2006 | 06:54 PM
maxfior's Avatar
After some digging again...
https://www.s2ki.com/forums/index.php?showtopic=50775
I'll give it a good read!
M.
SheffieldSam
Oct 27, 2015 10:25 AM
JrJanowski
Jun 14, 2014 04:51 PM
nick300zx
Apr 5, 2013 01:26 PM
jackson1628
Jan 10, 2003 03:59 AM
S2k Dude
Jun 11, 2001 02:04 PM
