Alignment
Old Mar 19, 2002 | 12:42 PM
johnyboy32's Avatar
After reading a few posts about alignments, I am beginning to se a pattern. People who have done "alternative" alignments tend to leave the caster alone and add:
- more negative camber front and rear
- less toe in rear
- more toe in front
This would seem to be a formula for dialing in understeer. Does this sound right? I am getting new tires soon and will have an alignment done at the same time.
Old Mar 19, 2002 | 12:46 PM
mfabry's Avatar
Does anybody know if the factory alignment settings changed from 2001 to 2002?
Old Mar 19, 2002 | 01:02 PM
FSures's Avatar
johnyboy32, I can't answer your question. mfabry, if I remember correctly, someone posted revised alignment settings for the 2002 S2000 from Honda UK. You might search the posts. I saw the fact sheet but I couldn't get a legible copy. I also remember something about roll bar changes.
Old Mar 19, 2002 | 01:29 PM
dlq04's Avatar
Go to the Section "Under the Hood" and look up the thread "Post Your Alignment". There you will find (1) what the factory setting should be, (2) what several racer's and owner's have experimented with, and (3) what Honda of UK is now recommending for Brit owner's with '00 and '01 models - which is a change from what the factory settings were.
Anyone who feels their car has squirrelly handling, should first find out how it specs out compared to the original factory. That should always be your baseline. You should always know what the baseline is and how you compared to it. If it was wrong to begin with (and this has happened) and you change it to something else that's different, it might be better but still not as good as it could be. Secondly, for those wishing to try a different setting, assuming the factory setting is not to their liking, I would suggest trying the Brit's setting as it was developed under conditions good enough that they recommend it in their technical service bulletins.
Just my 2 cents.
Old Mar 19, 2002 | 02:54 PM
mfabry's Avatar
I called Honda USA and they said the alignment settings are the same for for 2001 and 2002.
Old Mar 19, 2002 | 03:03 PM
FSures's Avatar
I agree completely with dlq04. It seems that Honda specs their cars according to how they percieve their cars are going to be driven. We should keep that in mind before we attempt to place any "blame".
muha22752
Aug 24, 2012 02:10 PM
F22PwrdS2K
May 30, 2009 10:35 AM
notyourfriend
Mar 12, 2009 01:31 PM
Mole
Dec 20, 2003 02:51 AM
