annoying noise!!!
Rich, I've had two very similar noises that the Shin-Etsu did not fixed.
Two separate things, first was a rattle that someone on this board identified (I think Pinky) and the second from the latch not being tight enough (can't figure out how to adjust.
Fix for the first noise was to stop the plastic cover under the lever from rattling. I used some foam tape in the side gaps.
The temp fix I've used on the second issue was to stick the corner of a business card under the hook and clamping it in there. If the hook were threaded or something I'd of just screwed it in one turn, but it's not.
Can anyone figure out how to tighten this joint?
Hey, I'm a hater of noise here too. I am in fact in the middle of dynamating the whole damm car. But anyway, after removing the latches (2 phillips screws) take it apart and use a little grease, after a thourough cleaning to make the latches rattle less. Then use foam or tape (I used a piece of dynamat) to cover the inner side of the black plastic piece. Finally, go buy some tubing from your local home depot. I think roughly 2 cm in diameter and made out of soft rubber. The kind I have is black (if that helps). The clear tubing is a little too unflexible and hardens in the sun. So avoid it. Cut off an inch or so place over latch hook. Voila . Much tighter non noise making modfor.87 cents.
Hope that helps!
Hope that helps!
Originally posted by mingster
ok, i've just about had it with the noise coming from the forward passenger side. this "gggsss, gggzzz, gggzzz" vibration/rubbing sound when i'm driving on the freeway with the windows and the top up. it sounds like the top is making the noise, or the latch, or the window/rubber piece rubbing. whatever it is, it's REALLY annoying.
any suggestions?
any suggestions?
Originally posted by viscreal2000
Hey, I'm a hater of noise here too. .................................................. ......... Finally, go buy some tubing from your local home depot. I think roughly 2 cm in diameter and made out of soft rubber. The kind I have is black (if that helps). The clear tubing is a little too unflexible and hardens in the sun. So avoid it. Cut off an inch or so place over latch hook. Voila . Much tighter non noise making modfor.87 cents.
Hope that helps!
Hope that helps!
Did a slight variation, hope you don't mind
, put some 1/4" heat shrink tubing on the hooks and shrunk it. If you didn't know better, it looks like it might be stock.Hope it lasts, time will tell.
