Annoying Problem...Pls Help
Old Jun 20, 2005 | 03:32 AM
rikhemi's Avatar
Default Annoying Problem...Pls Help
To make a long story short, I purchased ricks clear diffusers for the headlights around a month ago. Everything went fine, had no problems that day. A couple of days later, I notice that one of my headlights are getting humidity inside of it(prob cause it rained for 2 days str8). I then took the headlight off the next day I could when the weather permitted me and blow dryed the inside of it and siliconed the headlight again. I put it back, seemed to work until 1 1/2 later when im washing my car, the headlight gets humidity again. I took it out again and looked through the hole headlight and couldn't see where the opening is. There was probably an 1 ounce of water build up inside. It had a little puddle inside when you turned the headlight facing upwards. I had to blow dry the inside again and I just put it back. What else could i do to help this situation. Is their another product I could use to help me with this. Any advise would be appreciated.
Thank you
Old Jun 20, 2005 | 04:09 AM
MattG's Avatar
Drill a small hole near the bottom of the headlight to allow the water/humidity to escape?
Old Jun 20, 2005 | 04:49 AM
reds2's Avatar
Take it out and reseal it. You need to put on a ton of silicone sealant. Actually when I first cleared my headlight, I did a piss poor job with the driver's side and a beautiful job on the passenger's side. I hardly used any new silicone on the passenger side. I think I have to pull the driver's side and put on a ton of sealant. My left headlight has light condensation after washing, but I am too lazy to reseal it.
Old Jun 20, 2005 | 07:21 AM
rikhemi's Avatar
Is there any other materia I could use.. Also, the silicone i used when i put the headlight back on, will that melt with 220 degree's like the honda glue. Isnt the silicone stronger than the factor glue?
Old Aug 23, 2005 | 08:57 PM
S2000_TYPE_S's Avatar
Having the same problem:
which kind of silicone provides the water / air protection that is neeDED?
Old Aug 24, 2005 | 03:50 AM
Poindexter's Avatar
easiest thing to do.
Old Aug 24, 2005 | 04:27 AM
rikhemi's Avatar
You dont need to drill a hole.. I know exactly what you are going through. I too purchased ricks product and had problems numerous times with the right side headlight. I first resealed the outside. Didnt work. Then I opened it and resealed it again.. still didnt work.. Then I resealed it over again since i didnt want to open it again. Still didnt work. Finally, I opened the headlight again, resealed it and sealed all the plug ins for the bulbs by the outside and it did the trick. Its been great for a month and I live in florida where the humidity is horrible for not properly sealed headlights. Hope it helps.
Old Aug 24, 2005 | 06:32 AM
Kodokan_4's Avatar
I recommend flowable silicone for resealing the headlights. Flowable silicone will seep into the nooks and crannies, and seal it up airtight.
I don't think the headlight s can be split again after sealing with silicone.
I cleared mine about 3 years ago, with no leaks or other problems.
-Pete
TofuProductions
Apr 30, 2015 04:22 PM
cpx3mbp
Sep 24, 2009 11:37 PM
xrapidx
Jul 8, 2009 05:58 AM
buyos1717
Oct 14, 2007 04:54 AM
Jaded41
Oct 26, 2001 11:10 AM
