anyone uses this?
Old May 9, 2006 | 08:32 PM
D-S2K's Avatar
Default anyone uses this?
if so, does it really make a difference in your car's cooling ability?
Old May 9, 2006 | 08:41 PM
revhi's Avatar
Comptech recomends it for there aftercooler. Doesnt make a difference? Who knows.
Old May 9, 2006 | 10:22 PM
rice_classic's Avatar
[QUOTE=revhi,May 9 2006, 08:41 PM] Comptech recomends it for there aftercooler.
Old May 9, 2006 | 10:30 PM
cthree's Avatar
Administrator
it is used for race cars that cannot use glycol based anti-freeze. It's not an additive to coolant. It is a substitute used to reduce the surface tension of water and raise it's boiling point. It is for race cars not street cars and shouldn't be used in a street car.
Old May 10, 2006 | 12:59 AM
darkfx's Avatar
I've been using it on my cars for the past 4-5 years with no negativee effects
Old May 10, 2006 | 01:57 AM
energetic's Avatar
I agree with cthree.
Old May 10, 2006 | 05:55 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Just use a few drops of dishwashing liquid soap;same f@#$*ng thing.
Old May 10, 2006 | 05:57 AM
S2kracka's Avatar
It can be mixed with either straight water or a water/coolant mixture. Only use it if your cooling system is having trouble keeping up with additional heat created by a turbo system, supercharger system, etc. There is no reason to put it in a nearly stock S2k. Our stock cooling system should even be able to handle the stresses of track use. A few drops of dishsoap in your coolant will do basically the same thing aslong as you are using a water/coolant mixture.
kylemonster85
Jan 22, 2009 05:39 PM
kylemonster85
Oct 12, 2007 01:52 PM
Enthralled
Feb 1, 2007 07:30 AM
Quick_Silver
Jan 28, 2007 03:35 PM
bobbyb
Sep 14, 2005 09:32 AM
