Bad day...radiator and headlights suck.
Old Mar 11, 2006 | 03:45 PM
GroovyNeilNeil's Avatar
Banned
Default Bad day...radiator and headlights suck.
mkay...so my radiator is leaking. Honda said don't drive it, I don't have that luxury to just not drive. What are some immediate options when it comes to fixing or replacing the radiator?
mkay...so my headlights went out. Honda is telling me I need both headlamp igniter assembly's. Would it be better for me to buy two of those ($350 each) or just buy the whole new headlamps? I have a 2000 s2000, can you fit the newer headlamps in the older s2000's?
Old Mar 11, 2006 | 04:24 PM
dhayner's Avatar
Unlikely both headlights would fail simultaneously - look for some one thing that affects both headlights.
As long as you keep adding enough coolant to keep the overflow tank level above min, of course you can drive the car. Yes, it'll leak onto the floor or street until you get it fixed, but you're going to do that soon, right? (I'm assuming your temperature gauge is reading normal.)
Old Mar 11, 2006 | 04:48 PM
Banned
Ya, the temp guage is staying normal. One headlight went out, then two months later the other headlight went out. The honda guy said that air got in the radiator and i'm running a risk of blowing a head gasket.
/shrug
Old Mar 11, 2006 | 05:16 PM
Slows2k's Avatar
It doesn't take long to damage an engine from running it hot. Drive it at your own risk.
Old Mar 11, 2006 | 05:35 PM
dhayner's Avatar
/shrug
It would have been more helpful if you had mentioned this in your first message.
Air in the radiator is not a radiator problem; it's a cooling system filling problem. And you do need to get the cooling system full, or overheating will damage your engine. Check the last part of xviper's post on radiator flushing.
Old Mar 11, 2006 | 07:56 PM
xdavieexx's Avatar
if u want buy a koyo radiator when you get money its about 350.
Old Mar 11, 2006 | 11:24 PM
Banned
Maybe I should have said all the details in the first post. The radiator is leaking fluid. It's all over my engine bay and is also running down the bottom lip of the front bumper. However, I just got it home from the Honda dealership and I haven't seen any fluid on the ground or any fresh, wet fluid in the bay. It's all just dried up and white now. I'm taking it to a radiator shop tomorrow to see what they have to say.
/crosses fingers.
Old Mar 12, 2006 | 07:14 AM
04RioS2k's Avatar
um maybe you don't see any fluid because there might not be any in the radiator? so just check to be sure as some dealership are just plain incompetent....
Old Mar 12, 2006 | 09:29 AM
Banned
There is fluid in the radiator, and it's not dripping anywhere. However, the little foam (i know it's not foam, but the absorbant thing in front of the radiator when you're looking down at it) thing is soaked with fluid. I'm in the process of removing the radiator so I can take it to a shop to be fixed.
What about the headlights? Will 04-05's fit directly in a 00's location?
Old Mar 12, 2006 | 07:03 PM
Incubus's Avatar
MacGyver put eggs in a radiator once...the heat boiled the eggs and they clogged the holes.
I'm not talking about the Macgyver on this board, but Richard Dean Anderson.
Polemicist
Car Talk - Non S2000
Aug 9, 2014 11:23 AM
jason4207
Feb 20, 2013 05:37 AM
SstoneS2k01
May 11, 2004 07:14 AM
PatrickCBrown
Jan 13, 2004 05:39 PM
xXSeXoHoLikXx
Dec 18, 2003 01:23 PM
