Bad Misshift
Old Sep 18, 2004 | 04:47 PM
LivingLegend's Avatar
Default Bad Misshift
Last night i was getting on the freeway on ramp and i was at around 8k in 3rd. I tryed shifting into 4th but stupidly and acidently shifted into second for a split second i dont think i even caught it, but aparently i did. My car did start today in the morning but was working fine last night with a slight rough idle. I had to towed to Acura and they got me at $800 just to take the block apart and find the problem. They are then going to send my head to another shop and get it fixed. Could i have gone to a private mechanic to get this done? I know the guys at Acura well and i know they will do a good job but for an expensive cost. If it is really bad what do you guys suggest on a rebuild.
Old Sep 18, 2004 | 05:19 PM
kkyntmoon's Avatar
Wow!
Everysince I posted in the NY forum about my mis-shift 2 weeks ago,
It seems like this topic is coming up everywhere now! That is really REALLY weird.
Hope everything works out for you.
Keep us Updated.
BTW: A complete head from hardtopguy.com cost $2289.59 + Shipping. Seems like you'll be paying more then that allready.
Old Sep 18, 2004 | 05:22 PM
SilverKnight's Avatar
you could always have freinds help you or go to a private mechanic def cheaper!! Dealerships rip you off....
Old Sep 18, 2004 | 07:08 PM
A somewhat good thing...the dealer called me after i droped it off and said they got it to run, but its really rough. Do you still think ill need a new head?
Old Sep 18, 2004 | 08:22 PM
wheres xviper!!
Old Sep 18, 2004 | 08:30 PM
Originally Posted by SilverKnight,Sep 18 2004, 08:22 PM
wheres xviper!!
Could he help me, i cant stand this, i feel so dumb and i have so little money.
Old Sep 18, 2004 | 08:43 PM
S2KANDRE's Avatar
you can always pm the GOD (aka xviper)... Anyways I kind of dont get how you misshifted from 3-4 (thats just a straight shift), i would understand if you went from 2-1 or 4-3 you know what im saying?
Old Sep 18, 2004 | 09:12 PM
yogi's Avatar
If it's running rough, there is probably a bent valve or something similar. I've had this problem in the past and ended up fixing it myself with some help from a machine shop (Joe Alaniz). The dealer is going to charge you and arm and a leg to fix it. Get a private shop to remove the head, take the head to Alaniz http://www.alaniztechnologies.com and have the shop install the head after Joe checks it out.
Old Sep 18, 2004 | 09:16 PM
S2KANDRE's Avatar
^ sounds like a good idea to me...
yogi's Avatar
Wait a sec...the Acura dealer charged you $800 to take it apart, then called you back after and said they got it to run? Did they do any diagnostic? Or did they just push the start button and say, "Hey, it's working!" ?? What you really need to have done is a compression test to see which cylinders are giving you problems. Once you have that information, move to removing the head from the block and inspecting the block, pistons, valves, seats, head, etc. Then you'll be able to make a better decision about what you need to do and who should do it.
Just curious, did your check engine light (CEL) ever come on?
