is it bad to start in 2nd gear instead of 1st?
Old Jan 1, 2004 | 03:52 AM
bobatimez's Avatar
Default is it bad to start in 2nd gear instead of 1st?
? thnx
Old Jan 1, 2004 | 04:09 AM
GeorgeP's Avatar
Why would you want to?
Old Jan 1, 2004 | 05:19 AM
Barry in Wyoming's Avatar
Yes, except on ice.
Old Jan 1, 2004 | 07:14 AM
jankemi's Avatar
I do it all the time on my Jeep & truck. Both have enough low-end torque that they start out easily in second. A second gear start will increase clutch wear, but decrease 2nd gear syncro wear. I started the (bad) habit when I had a Jeep with toasted syncros that would not make the 1->2 shift when the temps were below 0F. I'd have to either start out in 2nd or try to shift 1->3. I still do it about 1/2 the time - mostly out of habit & lazyness.
I don't think I like doing it on my s2K though. Not enough torque, so too many revs are needed, & seems like too much clutch wear.
BTW - the Jeep has 140K miles on the original clutch.
--Mike
Old Jan 1, 2004 | 07:57 AM
Russ's Avatar
In high torque cars in the snow or heavy rain, it's probably recommended but we have such little torque
down low, in bad traction weather (rain/snow), lst is fine.
Old Jan 1, 2004 | 08:27 AM
Chadwick's Avatar
Unless you are using stock rubber in snow and ice, than even good ol S2K has problems.
Old Jan 1, 2004 | 08:31 AM
Black Nugget's Avatar
i personally wouldnt do it. mostly cause it doesnt really do anythign for you. there's really no purpose to. however if you had a major reason, like a syncro was out or something of that nature then i'd do it cause i have to. but otherwise, naw i'll stick with standard procedure
chad
Old Jan 1, 2004 | 11:48 AM
Tugz_S2K's Avatar
Banned
Whats the point? Even if on ice/snow, 1st gear shouldnt be a problem for the S2.
Simply you will probably do lots of harm to your drivetrain if you start in 2nd on the S. There is not enuf torque to get you going. You will put more wear on your clutch.
I had a 86 Jetta VR6 and the car was so light and there was alot of torque, i could pull off the line in 2nd no problems. Wouldnt wanna try on my S....
drew260187
Mar 30, 2014 12:10 PM
_Kyo
Mar 5, 2011 03:30 PM
McS2K
Apr 19, 2006 02:01 PM
s2konda
Jan 26, 2005 02:46 AM
ju17
Jun 14, 2002 12:04 PM
