Best Springs
Old 10-25-2004 | 12:54 PM
vtecvoodoo's Avatar
Eibach is the only logical choice here.
Old 10-25-2004 | 01:52 PM
stingerbtry's Avatar
Tein S-techs work great for me. 1" drop front and rear and ride a little stiffer than stock with a great handling improvement.
Old 10-25-2004 | 04:39 PM
S2KPUDDYDAD's Avatar
I am going with the Spoon Sports progressive coil springs (about a 1"drop all around)
Old 10-25-2004 | 05:24 PM
RazorV3's Avatar
Originally Posted by ChopperDave,Oct 25 2004, 04:33 AM
how much do the kg/mm drop? and how is the ride?
depends if you get the supesport or race springs. supersport drops 15 mm while the race drops 35 mm. springs rates for the race springs are 8.9F/9.8R, which is pretty stiff but these springs implement dual rate technology. when you're cruising, the ride is smooth...but the springs get progressively stiffer as you start making turns.
i'm running the race springs with koni yellow shocks .new shocks are necessary, your stocks will handle fine for a bit but will noticably get worse as time goes by. my shocks are set right between full stiff and full firm, the ride is absolutely incredible.
Old 10-25-2004 | 06:26 PM
Will the stock shocks hold up better with the supersport springs? I do not want to go to low anyway. Thanks
Old 10-25-2004 | 06:29 PM
jdmdohcpower's Avatar
Tein s-tech is another option for me since ebiach and the s-tech are both 1 inch drop and thats all I want. My consern is that tein my be a bit too stiff which I know the eibach will be pretty much the same as stock - anyone know how the eibach feels?
Old 10-25-2004 | 07:09 PM
RazorV3's Avatar
they'll eventually wear out...either do it right the first time or don't do it at all. you will definately end up getting new shocks down the road, why not save time and $$$ and have it all installed at once.
dasmb1024
08-07-2012 04:44 AM
mistuhtimbuhlake
02-12-2009 05:30 PM
S2K913
07-08-2008 09:55 AM
05berlinas2k
05-12-2006 12:05 PM
9K
07-28-2003 12:52 PM
Quick Reply: Best Springs
