Better bumper protector installation? (Coastal Metals)
Did I say "bumper protector"?? I meant the radiator screen.
Has anyone found a more creative way of installing the Coastal Metals radiator screen other than their plastic ties? Some of my ties have "given out" - luckily two were still holding on! Seems like there should be a better way.
Originally posted by matrix
I think he is talking about the side grills, not the main grill.
You could always check out your local hardware store and try and find some "L" brackets.
Mount them on the fins of the factory grille (in the center) and then use a screw to attach the new grille.
You can do the same on the side or just leave enough of a piece of the original brake duct to screw into.
I've got the grille tech grille and used tie wraps initially but have some "L" brackets I found and will swap out when I get the time.
(Grille tech grille and "L" brackets still come out alot cheaper than buying the coastal grille. JMHO)
Yes, just duplicate the Coastal Metals way. Buy a couple of L brackets at the hardware store. They will probably be too long so cut off each leg as needed. Spray paint them black. There are bolts near each end of centerl grill slat that you can use to mount the brackets. Then use a couple of screws thru the grill to mount it. If you have a tap and die set you can tap a hole in the vertical part of the L bracket and use a machine screw to hold grill in place. Otherwise you can use a sheet metal screw.
AndyDoh
Sep 18, 2002 06:28 PM
