"Blipping" for rev match..
[QUOTE=littlerocket777,Nov 6 2006, 07:31 PM] So can I run the steps through you guys and let me know if I am correct?
For downshifting for a turn, say 4th to 2nd.
I'm off the gas > clutch in > shift from 4th to 2nd > rev to the correct RPM and hold gas there> release the clutch?
Is that how it's done?
I rarely ever look at my RPM's when rev matching, it's all a feel for the car really.
This is how I do it...
1) Release Gas
2) Clutch In
3) Blip while moving it into lower gear
4) Clutch out right after
I don't think I ever hold the gas and keep it at a constant rpm before clutching out. The transition when you clutch in - blip - clutch out should all be smooth if you do it correctly. I release the clutch right when I shift into the lower gear.
1) Release Gas
2) Clutch In
Having owned nothing but manual transmission Hondas and toyotas all my driving life (almost 11 years now) I cannot stand riding with someone who has less than perfect shifting, rev matching habits. I want so badly to give them pointers to allow smoother gear transitions! GRRRRRRRRRRR
Originally Posted by jeffbrig,Nov 6 2006, 06:38 AM
And when you're REALLY ready for fun, practice double clutching from any gear to 2nd at 45mph. Clutch in, select neutral, clutch out. Blip the throttle up to ~6k, clutch in, grab 2nd, and GO.
It may sound complicated if you haven't done it before, but all the above can be done in a fraction of a second.
Disclaimer: The above activies are considered reckless, childish, and immature, but can be a lot of fun. mileage may vary. expectant mothers should not ride this ride.
On an aggressive downshift, you're asking quite a bit of your synchros to match the speed of the layshaft/gear to the speed of the drive shaft. Abuse these often, and one day you'll find yourself needing a lovely transmission rebuild.
Double clutching is a technique that allows shifting in transmissions that don't even have synchros, so it follows that there is less wear if you do this on aggressive downshifts. If your transmission is notchy, this will avoid the notchiness. By matching the speed of the rotating gear and the driveshaft, the dog teeth on the gear selector are able to engage cleanly without waiting for the synchroniziers to equalize the speeds.
It also happens to be the case that double clutching defeats the 1st gear lockout (the s2000 won't generally let you downshift to 1st if you're traveling >10mph), but I didn't tell you that...
Is that how it's done? Couple of questions. When you rev to the correct RPM, you do gas quickly or like really quickly? When you release the clutch after you've reached the correct RPM, do you still have to hold it there for that split second for a smooth transition, or do you just let it go?
I guess this is more of a heel-toe type of question..
Originally Posted by jonomo,Nov 8 2006, 12:52 AM
Rev matching to accel or maintain speed is something i've been doing since I learned how to drive stick.. HOWEVER, blipping for downshifting during decelerations.. i'm not sure if you're suppose to release the clutch as the RPMs go up, down, or at its peak...
Heel toe is along the same lines but don't jump into that just yet. Heel toe is just a little awkward at first but if you can rev match you will be able to do it just fine. I have a bit of an issue because I find the gas pedal a little thin and a bit far from the brake compared to other cars i've driven. But then again it might be the dress shoes I have to wear everyday to work.
jaehoppa
Jul 14, 2007 12:40 PM
