Bring it on winter!
Old Nov 22, 2004 | 10:52 AM
  #41
scotchtape's Avatar
Nope not correct.
Old Nov 22, 2004 | 11:55 AM
  #42
Bass's Avatar
Originally Posted by The Hoth,Nov 22 2004, 11:34 AM
Hey cold start in the 30s is not necessary good for the engine. If the block heater is like a hundred or two, I think it is very tempting.
Anyone knows how much it is?
It's your money
block heater for the S - 75-80 bucks from hardtopguy
install maybe another 100 or so
drian all the coolant, remove plug, screw in heater, run and tie wrap heater wires (a 120v plug) out to the nose- install new collant, bleed coolant lines
if you keep it plugged in all the time expect a HIGH exlectric bill
Xviper - what are your thoughts - is this needed in Boston?
Old Nov 22, 2004 | 12:32 PM
  #43
Gasroth's Avatar
oh ok. I was jw cause I knew the regular tires were def not. I wonder why tirerack had it that way. Thx
Old Nov 22, 2004 | 12:56 PM
  #44
Woodson's Avatar
Very true, but not necessary to do so. Use an outdoor timer and set it for 20 or 30 minutes before you plan to start your car. It heats the block as much as it's going to in this length of time, even at 30 below.
Old Nov 22, 2004 | 01:15 PM
  #45
xviper's Avatar
I don't typically plug the block heater in unless the forecast is for temps going to below about -10*C (14*F). If it's going to be warmer than this, it's not really worth it except to get heat to the interior right away.
Old Nov 22, 2004 | 01:51 PM
  #46
Wisconsin S2k's Avatar
I haven't had any trouble starting my car in some very cold wisconsin weather days. as for wear and tear on the car, i'm not sure how much harm it really does or doesn't do.
we certainly get more than a handful of days that are in the single digits Fahrenheit, with 20 or 30 below wind chill.
Old Nov 22, 2004 | 03:48 PM
  #47
xviper's Avatar
I don't have any lab reports to quote but I do have an anecdote:
I worked with a guy who had a '60s Olds convertible. The actual brand of car is not relevent. He installed a second block heater in his motor and anytime the temps got even near -5*C overnight, he'd plug them both in. His engine is original and it has close to 300,000 MILES on it and it's still running strong. He attributes the longevity of his motor to it being plugged in when cold. He says it gets the oil moving faster and warmed up quicker and it brings the engine up to running temp much sooner than if he had to rely on its own BTUs.
Most certainly when I've had my car plugged in, the engine starts easier, stabilizes idle better and runs much smoother in the intial few blocks of driving. I'm not professing that this is good on the engine (or not). I leave it up to you guys to be the judge.
Old Jan 15, 2005 | 07:04 PM
  #48
Boatnurd's Avatar
This is the cold city of Milwaukee - right now it is a frigid -5 degrees. Burrrrrr.
bronxbomber252
Sep 7, 2012 02:48 AM
s2000cr
Oct 13, 2008 04:36 AM
s2korea
Dec 1, 2007 10:58 PM
00SpaYellow
Nov 9, 2003 01:04 PM
dlq04
Oct 10, 2002 08:15 PM
