Burn Out Question
Old Aug 6, 2001 | 08:08 AM
Nabs 79's Avatar
Default Burn Out Question
OK, this is probably a very ignorant question, but how the heck do you spin your tires out from a standstill without killing the clutch??
I am used to driving a front driver and you can easily get the tires of the Integras and such to spin when desired, but the S2k seems to be extremely difficult. Even a early 240sx was'nt a problem with rear drive. I tried at 4000rpm and it wont go!
Is it because of the LSD or the clutch, please explain!
Old Aug 6, 2001 | 08:13 AM
firsts2k's Avatar
I too had this problem. Smoked my clutch pretty bad trying to spin at 4500rpms. Then, I did a search on "launching" and found out that there is a "special" way to launch.
1) rev to 6500 rpms (vtec range)
2) pop the clutch out. Do NOT let it out slowly or you will smoke the clutch.
3) hang on!!!!
Try searching "launching" and read what everyone else has to say.
Old Aug 6, 2001 | 10:48 AM
MarkS2K's Avatar
If you also bump up your tire pressure, it'll be easier to burn out. Search the previous threads. Sev has a very good post on launching techniques.
Old Aug 6, 2001 | 11:16 AM
vtecvoodoo's Avatar
Wet your tires
Old Aug 6, 2001 | 11:25 AM
HeNeSSeY's Avatar
I dont think hes askin how to launch, I think he wants to do a burn out... If thats the case.. I say drop the clutch at like 8-9 rpm.
Old Aug 6, 2001 | 01:17 PM
RandyP's Avatar
Don't try with junk in the trunk, remove spare tire, remove passenger, adjust rear alignment for max negative camber, overinflate rear tires, or just turn steering wheel at 6000 + rpm when dropping the clutch and flooring the gas.
Old May 27, 2013 | 07:13 AM
pingels's Avatar
Or come to Turkey, where the roads are so slippery that all you have to do is drive normally. Tire spin happens. Want more? just push the gas pedal down quicker.
Old May 27, 2013 | 08:53 AM
s2000maniac's Avatar
Say bye bye to your diff
Old May 27, 2013 | 09:53 AM
MM3Kwolik's Avatar
You just bumped a 12 year old thread......
Old May 27, 2013 | 10:13 AM
deepbluejh's Avatar
Thread lock in 3...2...1...
williambjb
Jun 9, 2006 04:16 PM
Ahpat
Feb 24, 2005 07:47 PM
REV IT
Jun 9, 2003 03:19 AM
Eze8199
Aug 7, 2001 08:49 AM
StudentDriver
May 5, 2001 11:39 AM
