Carbon Fiber
Old Jul 12, 2004 | 10:00 PM
s2ka's Avatar
Wet or dry carbon fiber can be drilled, just use a very sharp drill bit and don't apply too much pressure (to avoid fraying the cf on the exit side of the hole). If it's a big hole you should drill a few pilot holes instead of one giant hole.
You can get the wet look back by applying spray-on kicker, then a few coats of very thin super glue (Zap Pink) to the edges, then polish it. All of those are available at good hobby shops.
Old Jul 14, 2004 | 12:02 AM
Stealth Operator's Avatar
S2KA's first paragraph sums it all up. Angle grinders work fine on carbon as well. Always control strength and pressure, any conventional workshop dremel/cutting tool with a decent cutting bit/teeth would not fray or destroy the product. Taping which is also mentioned above before attempting to drill would be ideal as well.
Old Jul 14, 2004 | 06:45 AM
efthimios's Avatar
yeah, I started last night with high speed and light pressure...you can barely even tell it was dremmeled, left the edge very smooth...thanx everyone
Old Jul 14, 2004 | 07:00 AM
MacGyver's Avatar
Compared to standard steel bits, Tungsten Carbide bits retain their edges quite well when drilling into glass fiber-style materials. CF is similar in nature to FR-4, the material used to create my PC boards...stuff turns steel bits to dull wire after 50 holes
Kiwiflavored
Jul 5, 2016 08:01 PM
The Loon
Car Talk - Non S2000
Mar 11, 2011 08:15 AM
darkwatch
Jun 15, 2008 10:56 AM
Legend S
Sep 20, 2007 11:23 AM
amongmany
Jun 30, 2006 05:03 AM
