changing amber lights to clear
Old Jun 2, 2002 | 08:15 PM
Hamada's Avatar
Default changing amber lights to clear
I was thinking about changing my amber lights to clear. I also wanted to chage to clear corners. If i do this will it take away from the safty of the car? By this I mean will people still see the light flash in the day?
Thanks guys
Old Jun 2, 2002 | 08:28 PM
xChungHsienx's Avatar
well it won't affect the safety. the bulb is still the same and will be just as bright, if not brighter. but i think its quite costly to clear our the headlight. side marker is easy. has anyone cleared out their blinker in the headlight housing?
Chung-Hsien
Old Jun 3, 2002 | 04:26 AM
darkknight1999's Avatar
Its not that hard really I did it in about 3-4 hours. Only cost was the cost of the sealent--$20 from my dealer. I purchased replacement windshield adhesive, it work very well.
Here are the directions to do it youself. Clearing headlights If you need help just ask.
Old Jun 3, 2002 | 04:29 AM
BTW after you clear the lights you can get amber bulbs. I used hyper white. Either way, they flash brighter after you remove the lens.
Old Jun 3, 2002 | 03:41 PM
Hamada's Avatar
Thank you very much for the info
Old Jun 3, 2002 | 03:54 PM
MeTh222's Avatar
I did my headlight clearing at Generation 1 in Anaheim, CA. It's a few blocks past disneyland and they do a very good job. Total cost is $145 which is very reasonable (includes hyper white bulbs) but it takes about 2.5 to 3 hours.
Old Jun 3, 2002 | 05:57 PM
Sime's Avatar
$20? !!!!! I bought a tube of black windshield sealant from Autozone for $6. Worked perfectly.
Hamada, If you do a search on the forum, you will find many articles on how to do it. I had to set my oven at 215 degrees to get the lights apart. You can't rush the job, but I believe the results are definitely worth it if you have some patience!
Oh, and I went with the Hyperwhite bulbs too. There has never been an instance of someone not seeing my turn signals.
HTH
Old Jun 4, 2002 | 04:01 AM
[QUOTE]Originally posted by Sime
[B]$20? !!!!!
zam.zx
Feb 3, 2009 11:33 AM
s2kinfinite
Aug 25, 2007 07:26 AM
tekAP1
May 21, 2004 02:04 PM
hebertjb
Aug 8, 2002 11:29 PM
Lightning
Apr 27, 2002 03:33 PM
