Changing the oil on Jack stands
Additional ideas:
While you have the tires off, inspect them closely. Inspect each tire for wear. Locate the wear bars. There are small arrows on the sides of the tires to pin point the wear bars on each tire. What your hoping to find is even wear across the tire and around the tire.
Do your 'final' tightening of the lug nuts to the 80# torque wrench specs after the car is settleed back down on the ground.
And I agree, the oil should generally be warm before draining to get the best flow. A drive around the block is sufficient. The drain nuts have an inside lip that allows you to do the final removal with your fingers. It allows you to hold on the plug and move your hand out of the way so you don't have to worry about getting it on you (no glove really needed), just allow for the pressure when placing your container under it. If you do drain it cold I would let drain for 1/2 hour. Finally, I always put at least 1/2 quart in the new filter before replacing.
What the S2000 and many cars need is a jacking point that allows the whole side of the car to be lifted. THe NSX has that and makes it very convenient to do wheel/tire changes... On the RSX, the front one is positioned such that lifting there pretty much lifts up the whole side of the car. But on the S2000, the front or rear has to be up quite a bit before the other end goes up.
[QUOTE]Originally posted by meat
My oil changing/wheel cleaning technique...
1. Engage parking brake
2. Loosen Lug nuts.
3. Raise passenger front with the scissor jack several inches to make room for floor jack.
4. Raise entire front with floor jack.
5. Put jack stands under the front/side jacking points and lower the car onto them.
6. Raise rear of car with floor jack (plenty of room to do this).
7. Put jack stands under the rear/side jacking points and lower the car onto them.
8. Pull the wheels.
9. Put oil pan under car.
10. Remove drain bolt.
11. Remove filter.
12. Clean wheels/wheel wells.
12a. Bleed brakes if needed.
13. Moisten new filter rubber with oil and replace filter.
14. Replace drain plug with new washer (I use a torque wrench to get to proper torque)
15. Refill oil to top of "X's" and replace the oil cap.
16. Start car and let run for a couple of minutes.
17. Verify oil level.
18. Replace wheels
19. Lower rear of car.
20. Raise front of car off stands and remove them.
21. Replace scissor jack under passenger/front of car.
22. Lower car on to scissor jack.
23. Remove floor jack.
24. Remove scissor jack.
25.
2. Loosen Lug nuts.
8. Pull the wheels.
11. Remove filter.
18. Replace wheels
25.
Originally posted by Destiny2002
Change your oil & filter from above the car, no tools!
http://forums.s2ki.com/imagecatalog/imageview/43933/6/
Changing my oil takes 10 minutes now.
Wouldn't want you to dehydrate.
