Chassis Stiffening Components
Old Mar 21, 2006 | 08:50 PM
IIGQ4U's Avatar
Default Chassis Stiffening Components
I don't know if this is in the right area or not but I was wondering what front end chassis parts you recommend to reduce oversteer in the API.
Do you recommend one of the X Brace units with an upper tie rod?
What do you all suggest?
I appreciate any assistance.
Old Mar 21, 2006 | 11:06 PM
aronparsons's Avatar
A larger front sway bar will reduce oversteer at the limit. There are a few non-adjustable ones that will suit you fine for street driving. If you're looking for a solution for autocross, there are three choices. A search on "sway bar" should give you all the reviews and such you need.
A better solution is to take yourself to a performance driving event/school and learn to drive the car correctly. Avoiding bad inputs (driving errors), you will learn to not make the common mistakes that lead to undesirable oversteer.
Old Mar 21, 2006 | 11:51 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
S2K is a pretty neutral car.
Old Mar 22, 2006 | 03:52 AM
slimjim8201's Avatar
1. Stiffening the chassis will not reduce understeer.
2. Our suspension does not use a sway bar. I think that term was last used around 1975. The correct term is anti-roll bar (ARB).
3. Stiffening the roll-rate in the REAR of an already neutral car will make it tend to oversteer more. Stiffening the FRONT will induce more understeer.
Old Mar 22, 2006 | 05:35 AM
Just stiffen both ends;get the Muz sway(ahem..Anti-roll bars)bars.
Old Mar 22, 2006 | 06:04 AM
IIGQ4U's Avatar
So those products from Prestige are pretty good pieces eh? I will probably do that and then perhaps enroll in class or auto x event.
Thanks a lot.
Old Mar 22, 2006 | 07:01 AM
Thanks a lot.
Enroll my friend;that's the best thing,that can happen to your "S".
whitt1
Mar 30, 2010 12:46 PM
s2krev
Oct 30, 2009 08:25 AM
Amer
Sep 6, 2006 09:35 AM
Stw000
Feb 16, 2005 01:29 PM
t.c.
Jan 15, 2003 02:39 PM
