Clutch Chatter
Old Oct 16, 2002 | 12:55 PM
andrewewing's Avatar
Default Clutch Chatter
My 01 has 18k miles. Got the clutch disc replaced about 200 miles ago under TSB054. Car is AMAZINGLY quieter BUT it now has a little bit of clutch chatter when starting off from a stop. Not real bad but annoying because it never had it before.
Has anyone else had this problem after disc replacement? Do you think it might go away as new desk "beds in" with the old pressure plate? Anything dealer could have done wrong? Would appreciate any input.
Old Oct 16, 2002 | 04:35 PM
yuchen's Avatar
Well apparently .... if you only change the clutch disc and not the pressure plate and the flywheel, vibrations would occur. I guess I am lucky that my dealer changed the whole lot at 22000 ...
Old Oct 17, 2002 | 02:51 AM
lvs2k's Avatar
I sometimes get little chatter depending on how I release. If I'm careful, there is no chatter.
Old Oct 17, 2002 | 08:22 PM
junehhan's Avatar
I seem to get a lot of chatter, especially when launching the car from off the line on my new 02. I've got 3800 miles on it now and it was doing it from the very first day.
Old Oct 18, 2002 | 09:37 AM
baritone's Avatar
OK, I'm going to show my ignorance now. I've heard the term "clutch chatter" a thousand times over the years. But this is the first time I've had a car that made me care what it means. So could someone describe exactly what it is? Is it a sound, a feel, or what?
Is it harmful, or just annoying?
Thanks,
--Steve
Old Oct 18, 2002 | 09:46 AM
Flyin Wedge's Avatar
How to explain chatter?...I'll try but I don't know the tech stuff.....it kinda feels like the clutch is slipping fifty times a second then sends a vibration you feel from your feet to your hands.....anyone want to add to that?
Old Oct 18, 2002 | 10:44 AM
That says it pretty well. In it's worst form it is impossible to start off smoothly from a start. The car just shudders or vibrates as you engage the clutch. You feel it, not hear it. It can be mild or severe. Similar to what someone said about obscenity, "you'll know it when you have it"
Old Nov 8, 2002 | 10:39 AM
I am pleaed to report that my clutch chatter that I reported after the TSB has about 95% disappeared. Apparently it was a high spot on the disc and/or it needed to "bed-in" with the old pressure plate. Anyway, all is well after about 500 miles of driving. Just wanted to let you know in case anyone else has the problem in the future.
wankun
Oct 26, 2016 01:18 PM
emaos
Jun 26, 2015 10:19 AM
Ron
Jun 2, 2007 01:23 PM
Beave0101
Nov 30, 2004 02:07 PM
Jonas Hedvall
Jan 9, 2001 09:58 PM
