clutch and flywheel Q?
upgrading my clutch wondering if i would have to change out the flywheel
looking to go with a
ACT stage 2 kit
ECM stage 2 kit
if so what are some opinions on flywheels
ACT stage 2 kit
ECM stage 2 kit
Why is the resurfacing necessary?
I thought one could just switch out the PP and friction disc and be done with it.
Is it necessary on all cars regardless of mileage or is it mostly for higher mileage cars?
Thanks
Dan
Thanks
Dan
once you're getting a clutch job done, you're already going to be spending a good amount of money or (if you're doing it yourself) your own time/effort so you might as well get a new flywheel. once the tranny is dropped for clutch replacement, changing the flywheel takes a negligible amount of extra time.
Okay, I understand your point of replacing a flywheel while they're at it.
But why the resurfacing? To prolong the life?
What happens if you don't resurface it?
Thanks for answering all the noob questions.
Dan
Dan
Resurfacing the flywheel removes any kind of warping that may be present with your old clutch, and removes the wear created over the course of 60k miles.
You resurface it to make it smooth again, thus increasing the life of the new clutch and keeping it in good running order.
