coilover worth it?
Old Apr 6, 2006 | 07:39 PM
deepee's Avatar
i dunno what road conditions are like in your area, but coilovers are acceptable here down south. im on tein flex coilovers and it's slightly stiffer than stock. it handles great too.
i was just at the track few weeks ago and noticed slight more over steer, but once you figure out where the breaking point is...you'll be find.
also, if you want coilovers...you might want to look at a full set up with shocks and upper mount.
Old Apr 7, 2006 | 04:21 AM
efthimios's Avatar
Originally Posted by geoff2005,Apr 6 2006, 10:31 PM
what kind of coilovers did you switch to
Buddy Clubs...very happy with them also
Old Apr 8, 2006 | 01:42 AM
geoff2005's Avatar
after talking to couple people and reading replys seems like coilovers are best
Old Apr 9, 2006 | 10:24 PM
passmans2kny's Avatar
jic flt a2s, very happy, very stiff and unforgiving, the back end def comes more now then it did stock
Old Apr 9, 2006 | 10:44 PM
geoff2005's Avatar
i dont know anything about racing or gripping but isnt that bad if the back kicks out rather then huging the turn
Old Apr 10, 2006 | 01:51 AM
zbrewha863's Avatar
So let me get this straight -- you are budgeting $1k for your spring/shock combo, or for your entire suspension setup? If I were you I would figure out which auto-x class you want to run in, and then figure out which suspension mods you are allowed to have in that class. The S2K is a suberbly-handling car from the factory, so you can run with the head of the pack in stock or some of the lower classes and keep your stock shocks/springs. Depending on the class (and sanctioning body) you may be allowed to change swaybars, bracing, or even tire size whereas if you change your shocks and/or springs you get bumped up into a much more competitive class.
My advice would be to stick with SCCA Solo Stock Class -- that will let you change the shocks/springs however you would like (incl. a set of coilovers), and change the front (but not rear) sway bar, but since the only real performance mods you can do are to change the air filter and the cat-back portion of the exhaust you have to learn how to drive fast, not let the car drive fast for you.
Old Apr 10, 2006 | 04:38 AM
efthimios's Avatar
how stiff do you have the rears set? (and what is the variance of settings)
Old Apr 11, 2006 | 10:01 PM
ok i got new tires 2 days ago and my back coming out isnt as much a problem, it never was its just for fun, im not saying my back end would tail out all the time, buit when i wanted it to, just eaiser than stock, mostly bc they set pretty stiff now, plus the drop
Old Apr 11, 2006 | 10:03 PM
i get 1 to 15 intervals, i just got cooper zeon zx5 tires, freaken sick tires
WRS2K
Nov 12, 2007 12:45 PM
inactiveuser1114
May 18, 2006 10:55 AM
Tonsafun
Apr 29, 2005 08:18 PM
thai12
Dec 22, 2004 09:41 PM
Ajjra
Jan 8, 2004 11:13 AM
