Comptech Exhaust/test pipe Intall questions
Old Nov 19, 2006 | 03:20 PM
THRILLR's Avatar
Default Comptech Exhaust/test pipe Intall questions
Just recently picked up a used comptech exhaust with test pipe from a friend (this is 147mphalldays old car).
Questions on my install:
The gaskets between midpipe and mufflers, can those be had locally, or do i have to order them through comptech. Alternatively, are they reusable?
There was what looked like additional bungs that the 02 sensor had on it. I didnt pick these up, and now that i think of it, they probably prevent it from coding...correct?
Old Nov 20, 2006 | 03:36 PM
THRILLR's Avatar
Any help on this?
Old Nov 20, 2006 | 05:48 PM
soozookabluS2k's Avatar
if the gasket is in good condition u can reuse em, i did and its fine. You can just get a gasket locally at pep boys or autozone wherever just get the right size. The test pipe has the bung for the anit fouler to stop it from throwing a CEL.
Old Nov 20, 2006 | 06:12 PM
THRILLR's Avatar
I am going to try and get some new bolts as the old ones look, well replacement wouldnt hurt is all i will say. The gasket I guess I will play by ear if it is needed.
Old Nov 20, 2006 | 06:23 PM
well yea if the bolts r rusty or anything it def would be good to just put some new ones, gaskets r cheap anyway..good luck
Old Nov 20, 2006 | 09:20 PM
helmet155's Avatar
New bolts, new gasket. Cheap and smart.
Old Nov 21, 2006 | 06:00 AM
gomarlins3's Avatar
Good luck with this. I tried at all of my local parts palces and NO ONE had the "figure 8" gasket needed. I just went without one.
As for the test pipe, the antifould trick has worked just fine for me.
SilliG
Jan 20, 2017 06:43 PM
Bliss@5200
Apr 27, 2007 01:14 PM
9grands2k
May 1, 2006 11:13 AM
