Comptech Intake
Well... I ordered my Comptech intake like about a week ago. Just received it today and installed it with one of my bois. Installation went well and everything but I have one issue about Comptech icebox. Their fitment sucks!
or is because I installed it wrong? Everything seems to fit in place and no rubbing issue with the hood either. Everything that came with the Comptech intake I used, except for 1 bolt and 1 screw.
There are suppose to be 3 bolts to hold down the box but I ended up only using 2. The 3rd bolt could not fit because there was a gap between the box and the metal piece that i was suppose to bolt to hold it together.
Another thing was there was 1 screw left that I did not use. The last screw was to suppose to hold down the carbon fiber piece. There are suppose to be 3 screws to hold it down but I ended up using only 2. The third pre-drilled hole on the carbon fiber piece was a bit off so i could not screw down the third screw. If I were to force it then i would have broke something.
Does anybody have these issues?
Pics would be helpful of how your comptech intake! Thanks guys!
or is because I installed it wrong? Everything seems to fit in place and no rubbing issue with the hood either. Everything that came with the Comptech intake I used, except for 1 bolt and 1 screw. There are suppose to be 3 bolts to hold down the box but I ended up only using 2. The 3rd bolt could not fit because there was a gap between the box and the metal piece that i was suppose to bolt to hold it together.
sedansrus
Aug 22, 2012 04:20 PM
