Convertible top keeps getting stuck!
Originally Posted by ThatPreludeGuy,Feb 2 2008, 09:20 PM
If you have an 07 why wouldn't you go back to the dealer unless you're already past your miles on the warranty. I'm not a fan of dealerships but I'd rather have it fixed and noted under warranty then messing it with myself.
But now I feel better knowing that this is common in S2K; I thought I had a lemon.
I will try the suggestions you guys gave me, I'll post updates later this week.
Thanks,
--David
Originally Posted by Reds2kracer,Feb 2 2008, 01:53 AM
You might want to check out Modifry.com, it happened to me awhile back 'til I'd got the convertible top fix that I'd bought from Modifry.com.
--David
Originally Posted by st_rage,Feb 2 2008, 07:52 PM
Be careful. My top tore. The problem with mine was that the rearmost stretcher bar was not coming all the way forward. I stop the top about 50% and make sure the bar comes forward now.
--David
the tops on the s2000s are made from POLYVINYL...not canvas. polyvinyl tends to be a bit more pliable in warm weather hence giving little to no resistance when retracted therefore you top going down all the way. cold weather does the opposite
-a
-a
You should fix how the roof is folding or suffer the same fate as we did
This has happenned a couple of times to my '07 as well...in colder temps. I figured out that it wasn't creasing correctly as it went down. From owning other verts, tops sometimes need to break-in (like a baseball glove) and form their natural creases. Once this happens, the binding shouldn't occur anymore.
Does the manual state to not lower the top under a given temperature?
Reason I ask is, I have the extended 100k mile warranty, almost at 100k, and I have a couple of tiny holes above my head from this very problem (I guess that bar didn't go back all the way in the cold so it put pressure on the vinyl). The holes are small and rain water does not get in yet but it probably will get larger over time and may be a problem in the future.
Can the top be replaced under the extended warranty?
