dash lights out...
Old Nov 14, 2008 | 02:33 PM
knlg's Avatar
Default dash lights out...
Anyone else experience the top half of the indicators around the climate control knob not lighting up? Recently mine have stopped. I give my dash a smack and they come back on.
I am guessing loose connection. Any ideas how to get behind that panel?
Thanks!
Old Nov 14, 2008 | 06:36 PM
detonator2x's Avatar
Mine are out, left half. Haven't given enough of a damn to check it out yet.
Old Nov 14, 2008 | 10:35 PM
DJ Qube's Avatar
Thanks!
Sounds like you have a bulb on the fritz. Probably not a loose connection, because the wiring harness snaps into the back of the climate control. There is one tiny bulb that illuminates that entire circle or symbols you're talking about.
There is no "simple" way to get to the bulb, but it is possible to do by yourself with some standard tools. You can follow the instructions in the link below for removing the audio control, which is pretty much the same procedure. The tools you need are listed in the instructions as well.
Good luck!
http://www.qube-engineering.com/Documents/...nstructions.pdf
Old Nov 15, 2008 | 06:06 PM
Blacknot's Avatar
Mine has been burned out for a few months in the same spot. Just half and i havent know how to replace the bulb. I will fix it now that i saw that link. Thanks
Old Nov 15, 2008 | 09:38 PM
REVHIR's Avatar
I been having the same problem for a year already.... i just bang it and it comes back sometimes.
Fils07S2K
Apr 11, 2015 05:21 AM
madness
Dec 27, 2011 04:37 PM
animeS2K
Jan 17, 2008 03:56 AM
omgvtec
Jun 21, 2007 12:31 AM
SaV
Nov 11, 2002 11:16 PM
