Dashboard vibration noise
Old Oct 5, 2006 | 07:10 AM
outdoorsmenfish02's Avatar
Default Dashboard vibration noise
Has anyone had a intermittent vibration noise coming from there dashboard.
Looking for any ideas and suggestions.
Thanks In Advance.
Old Oct 5, 2006 | 02:07 PM
Scrufy's Avatar
I have this same dashboard noise you are discribing in your post. Some times when I go over a bump at low speeds. Drives me crazy. I looked up under the dash to see what might be wrong but therre isn't much room up there to see what's going on. I thought about wedging something under the dash to quiet this noise but havn't found the right thing to do it.
Old Oct 5, 2006 | 02:34 PM
broken j o e y's Avatar
Grab the leather stick shift boot with your index finger, and thumb while your in 3rd, or 5th gear, and pull the boot up off of the shifter rod, and up against the base of the shifter knob, while your hearing the noise. On my car the damn leather boot actually vibrates on the stick part of the shifter, and it always sounds like it's coming from the dash. Kind of weird, but thats where my noise comes from.
Old Oct 5, 2006 | 07:12 PM
frofro24's Avatar
I have a raddle that comes and goes, It is my rear view mirror. I know it is not the dash, but sometimes you hear things in places they are not.
I hear the voices talking to me right now and I am all alone.
Old Oct 6, 2006 | 05:02 AM
Thanks for the replies. I did find in the search that someone found a repair to be opening driver and passenger door look for round plastic plugs on the inside corner of dashboard. There is a mounting screw check to see if loose. I did this seems to have solved problem thanks hope this helps you.
Old Oct 6, 2006 | 06:40 AM
Scott Evil's Avatar
Do you have an after market intake? The A/C line vibrates underneath my Comptech and that works its way into the dash. Some extra insulation smooths it out.
Old Oct 6, 2006 | 06:45 AM
AssassinJN's Avatar
My damn rear view mirrors rattles/buzzes too have to re-adjust it every once in a while to make it stop buzzing for a couple weeks or so.
Old Oct 6, 2006 | 07:30 AM
dangators05's Avatar
Scott Evil, could you PM me about the solution to the Comptech CAI rattle. I'm having the same problem.
Old Oct 6, 2006 | 09:38 AM
Scrufy's Avatar
My noise is coming from the dash. I faintly remember someone pulling a FURBIE (one of those stuffed toys) from under the dash to try to knock down the low rumble from the dash. Thanks for all the information guy's. I really appreciate your effort.
Old Oct 6, 2006 | 02:09 PM
ITRbroham's Avatar
I'm gonna' have to try this. For the longest I still haven't been able to pinpoint where the rattle is coming from the dasboard area.
j66
May 9, 2024 06:22 AM
alex.stanley
May 31, 2006 05:55 AM
cthree
S2000 Service Bulletins (TSB)
Mar 12, 2005 09:44 AM
danno1400i
Oct 28, 2003 10:21 AM
newguy
Oct 15, 2001 09:41 AM
