Dealer nightmare
Old May 11, 2004 | 12:35 PM
  #21
xviper's Avatar
Originally posted by blaks2k
Just checked the invoice. They have 10-30 as the oil but the little sticker said 5-20 in handwriting. Sounds like it was 5-20.
Also, no mention of rear diff fluid change. Isn't that standard @ 30k?
First, are you guys sure it's "5W20"? I thought that Honda was trying to go with "0W20" for most of their cars. In any case, for our S2000s, it is DEFINATELY 10W30 that should be going in there, however, a 5W40 is permitted for all temperature ranges.
Regarding the diff fluid change ..............................
MY GAWD NO!
They didn't get the engine oil right. Don't let them screw up the diff fluid as many dealers have done and resulted in ruined diffs.
Yes, diff fluid should be changed annually or every 15K miles.
Old May 11, 2004 | 12:54 PM
  #22
standard63's Avatar
My dealer didn't think there is a diff in my car. And they managed to put 15miles on my car, and didn't top off the coolant reservior after a flush. At least they didn't crash my car, and I'm driving it today!! Not going back there though...
Old May 11, 2004 | 02:56 PM
  #23
Road Rage's Avatar
5w20 is becoming a common oil for Honda, and for Ford as well. The 2003 SVT Cobra came with it, but it was the synblend made by Conoco, and is actually quite good.
5w30 is not equivalent to 10w30. It has more polymeric thickeners, is more volatile, and likely to shear down. In almost every particular case, given the choice between a 10w30 and a 5w30, the 10w30 is preferred, since it will be more stable, and likely slightly higher in vis at 100degC.
That dealer is horrible - they are nitwits. When they have a car in they do not -service much, they should be extra vigilant, not act like biz as usual.
Old May 11, 2004 | 03:22 PM
  #24
Slows2k's Avatar
0w20 is for the Hybrid's, Insight, and Civic. All other new Honda's besides the S use 5w20.
The POS Passport also burns 10w30.
The dealer could have screwed up the paperwork, or used the wrong oil. Since there is no easy way to check what they used, get it redone. There are good and bad dealers everywhere, for every manufacturer. Finding the good ones is the hard part.
Old May 11, 2004 | 05:20 PM
  #25
vvtli78k's Avatar
can you name the dealer? also maybe the guy puttingthe oil in must have dropped it on the valve cover to use the solvent, what an idiot.
S2KHUU
Feb 7, 2011 06:54 PM
Spiny Norman
Sep 25, 2006 08:57 PM
jyeung528
Nov 9, 2003 08:32 PM
Freds2k
Jul 10, 2002 11:37 AM
