Dialing out Tramlining?
Old Nov 6, 2002 | 09:44 PM
offroadr35's Avatar
Default Dialing out Tramlining?
For those who don't know, tramlining is when the tires try to follow ruts in the road. When i switched to the 18" rims the car tramlined quite a bit. After making sure i got all the pressures to 34psi, most of the tramlining went away. I want to try to dial out the little that is left but i don't know where to start? Do i want to raise pressure or lower it? Do the rears matter, or just the fronts? By the way the tires are the Kumho 712 225/35 and 255/40 or something like that.
-Steve
Old Nov 7, 2002 | 07:31 AM
offroadr35's Avatar
anyone?
Old Nov 7, 2002 | 09:09 AM
andrewewing's Avatar
My experience with tramlining is that it varies according to the tire (tread design probably) and gets worse as the tires wear.
Old Nov 7, 2002 | 09:36 AM
jeffbrig's Avatar
My experience is that the tread design and tread depth are the two main factors. In other vehicles, I've experienced it more with new tires than with worn ones. Haven't had any problems in the S2000 so far on stock S02s.
Old Nov 7, 2002 | 02:30 PM
offroadr35's Avatar
ok well i have the tires already. I bought them used but they still have decent tread left. I know pressures make a big difference, i just don't know what to change and which way to change it? Anyone?
-Steve
Old Nov 7, 2002 | 05:19 PM
2kturkey's Avatar
You should come to Melbourne - we have REAL trams and tramlining is something you can't do anything about - espec. in wet weather, those steel tracks do wonders to your steering. Don't try it on a bike either - it is real dangerous!
Old Nov 8, 2002 | 07:02 AM
auDD's Avatar
Trammeling (sp?) is a result of tire size also. The wider the tire, the more it is going to want to follow the ruts in the road.
Old Nov 8, 2002 | 07:34 AM
offroadr35's Avatar
ok guys, i know the causes, i realize it can be worse, i've gotten rid of most of it by changing tire pressures. All i want to know is which way should i change my pressures to try to get rid of the rest of it?
-Steve
Old Nov 8, 2002 | 08:58 AM
nEVERCLEAR's Avatar
I have 18's and I hope raising the pressure will help, just wanted to subscribe to this thread...
Old Nov 8, 2002 | 09:05 AM
wickerbill's Avatar
Is this really something you can totally get rid of? If there are ruts in the road, I don't see how adding a few pounds of pressure is going to make them totally go away. The ruts are still there.
RichV
May 27, 2009 01:21 PM
dmw16
Jun 24, 2006 08:27 AM
dyhppy
Feb 18, 2006 09:56 AM
s2kpdx01
Jan 16, 2004 05:18 PM
Zoinks
Jul 9, 2001 04:28 PM
