Diff exploded
On literally the last dyno run. I was having the 2step set and the guy was doing a 6000 rpm launch…boom. When I bought the car I was told it was a Puddymod rear, but I’m pretty sure it was stock.
I’ll be getting either a stage 2,3 or 4 from Ben (Puddymod) depending on what he says I should get.
380, but it was at clutch drop
im not sure if the stage 2 will tolerate hard launches. It’s cryo’d and beefy, but the stage 4 is like 3x the strength of a stock diff. I’d love to not worry about abusing the car.
.im not sure if the stage 2 will tolerate hard launches. It’s cryo’d and beefy, but the stage 4 is like 3x the strength of a stock diff. I’d love to not worry about abusing the car.
Thanks for the replies.
I’ve reached out to Puddymod and asked if their diff Would hold up to an occasional drag race launch. I believe their stage 4 will, but I’m waiting to hear back.
I’ll give the Nissan swap another look now.
Found a cryo treated diff locally. I talked to the owner about the history of it. He swapped in an r200. Seems worth the gamble.
After doing a bit of research it seems our diff need the better sleeve gizmo inside and they sure could use a brace to keep the carriers from walking (pic below).
I wonder how stout they’d be with just the brace, as that piece can be added by just taking the ball half of the case cover off. I found one seller of this piece, but it’s $1100 and it’s literally just 4 bolts and a metal cage.
