Different colored headlights...help
Old Jan 24, 2007 | 08:54 AM
soozookabluS2k's Avatar
u looking for the DIY on taking the headlights apart?
https://www.s2ki.com/forums/index.ph...pic=50775&st=0
Old Jan 24, 2007 | 09:08 AM
rugsr's Avatar
thanks for the link...i was more talking towards the "washer mod" ive heard people talking about
Old Jan 24, 2007 | 09:20 AM
i dont think theresa writeup on it but i can tell u how to do it. When u have the headlight apart, look at the half of the headligth which has the ballast and the hid bulb in the housing. U will see a gray cover which covers the hid bulb, u have to turn it to pop it off. Once u get that off u unclip the hid bulb. The hid bulb housing is screwed into the back of the projector part. u have to unscrew 2 screws in the back to separate them. Once u seperate then u will see the sheild right behind the prjector. U unscrew the sheild and u will see 2 "nipples" behind it. you add 1 or 2 washers behind it or however many u want and then screw back on the shield and put it back together. test it out though after u put on the washers to make sure its still got a sharp cutoff and the color your looking for. Sorry if its a little confusing but once u have it apart u will get the idea.
Old Jan 24, 2007 | 10:24 AM
rugsr's Avatar
so does this need to be done with the headlight apart...like in the oven on 275 and pop the glass out...or can i just pull the headlight off the car and do it?
if you need to bake the light to do this...how do you test it with the light still apart?
Really...theres no DIYs on this yet =(
americansailor89
Sep 27, 2011 05:11 PM
AlX Boi
May 17, 2006 05:12 AM
PAKS2K
Dec 17, 2005 12:03 PM
-JSL-
Oct 28, 2005 09:39 AM
GHS2K
Feb 14, 2003 03:59 PM
