Dirt and condensation in tail lights?
Old Apr 11, 2012 | 04:04 AM
vmacjnr's Avatar
Default Dirt and condensation in tail lights?
Hi there..... have had my S2000 for over 2 weeks now and was woundering if it was possible to remove the tail lights cover to clean the inside due to build up of dirt/dust and condinsation marks? Also my left chrome exhaust piece is loose..... honda say i need a new one costing £110 is there anywhere else i can buy the exhaust tip from cheeper? Replica maby? Cheers Vic
Old Apr 11, 2012 | 05:04 AM
dwight's Avatar
The exhaust tip is held on with a single screw. Why is it loose? Is it broken or rusted out? As far as buying a new one, ask people in the local forums.
Old Apr 11, 2012 | 05:38 AM
Vyndictive's Avatar
The tail light and condensation problem was common on my old car.
You need to move the entire tail light assembly. (very easy, remove the trunk carpet, remove the twist-in lights, and remove 4 nuts)
From there you can clean it out. There is no easy way to remove the clear lens only, though.
To keep it from happening again, you need to make sure that the tail light gasket is in good shape and seated properly. Upon inspection you'll be able to see where the gasket isn't seated properly against the light. If need be, order a new gasket.
Old Apr 11, 2012 | 07:25 AM
TougeS2k's Avatar
^^^^ very good advice, i have the issues with my driverside headlight, and i hear you have to "bake" that one
Old Apr 12, 2012 | 07:27 AM
vmacjnr's Avatar
Honda said it had been damaged while reversing, would it be possible to jst screw anouther screw on or weld it?
Cheers.
Old Apr 12, 2012 | 07:29 AM
vmacjnr's Avatar
Thanks Vyndictive gaskets available from honda i take it?
fat_louis
Feb 17, 2021 10:31 AM
GizmoPhoto
Mar 16, 2016 06:44 AM
Nicroman
Feb 28, 2014 04:11 AM
ans2k
Nov 28, 2011 07:17 AM
