Do you guys skip gears when taking it easy
Old Dec 11, 2011 | 08:32 PM
  #31
Sliversurfer_lmk's Avatar
stright up i skip 5th all day i hate that gear its probably the less abused out of the 6 lol
Old Dec 11, 2011 | 10:02 PM
  #32
mister x's Avatar
Beyond mechanical issues, skipping is bad technique. I understand the situation where you have to suddenly brake but in normal driving, it helps to build muscle memory to run through all the gears. The result will be smoother driving and better handling at the limits of adhesion. I wouldn't differentiate between cruising or hard driving, good technique should be a constant. I don't think a great quarterback forgoes proper footwork or timing because it's an easy throw.
Old Dec 11, 2011 | 10:46 PM
  #33
g0g3tt4's Avatar
Originally Posted by chuhsi
i never skip gears
Exactly. If I wanted to skip gears I would have bought an automatic.
Originally Posted by skkppy
skipping gears is for civics
Not enough motor to skip gears... but I don't do it there either.
Old Dec 12, 2011 | 01:44 AM
  #34
ZDan's Avatar
Geez...
Do it right and it is NO big deal. At all.
As for muscle memory, for upshifting this should obviously be nothing to worry about. That said I generally do not skip downshifts on the street for this reason, to keep in the practice of heel/toe and rev-matching. At the track, I do skip on downshifts. Fewer opportunities to interrupt threshold braking.
I only occasionally skip upshifts on the street, again, no big deal if done properly (i.e., not doing it from high-rpm, not bogging/lugging in the taller gear).
139k miles, 22+ track days, original clutch, original synchros, not a problem.
Any doubts at all, don't do it.
Old Dec 12, 2011 | 03:37 AM
  #35
redlineracing's Avatar
Most of my driving is @ Interstate speeds,so on the on ramps I'll get to speed in 4th,then skip shift to 6.
\rlr
carolina
Old Dec 12, 2011 | 04:20 AM
  #36
bmms8's Avatar
guys, i am a little confused, there is a lot of "its okay/not okay"
I never skip gears when upshifting, like many of you, i do not like 5th so i put it in 5th and put it in 6th right after.
i have a question when coming to a stop say from 6th. i have my foot down on the clutch and i usually take my shifter out of gear. say at 30 mph there is a green light, i will put it in 3rd while rev matching at 3k rpm. is this technique okay, or what should i be doing instead? greatly appreciated!
Old Dec 12, 2011 | 06:06 AM
  #37
Reckon's Avatar
I see no real need to skip shift on the upshifts. Skip shifting on down shifts makes sense and works well if done properly by selecting the right gear for the speed, rev matching, or double clutching.
Old Dec 12, 2011 | 06:22 AM
  #38
Triple-H's Avatar
65,000 miles, 7,000 of that done on track
I skip gears all the time, including on track
For all those who believe this is some sort of evil thing that will destroy this car I say bullchit
Like EVERYTHING ELSE, there is a right way to use the manual transmission, and a wrong way
Skipping gears is not wrong, but it can be done wrong
When skipping gears you just need to make the gear change slightly slower, let the poor little synchros catch up
Old Dec 12, 2011 | 06:25 AM
  #39
Triple-H's Avatar
I skip upshift frequently, this would be an example
Blast up to 9 grand in 1st, grab second, blast up to nine grand in second, slowly shift over to 4th
It was fun getting up to that speed, and now 4th is all I need so as to not be caught speeding
Old Dec 12, 2011 | 06:28 AM
  #40
Triple-H's Avatar
Originally Posted by ZDan
Geez...
Exactly, but too many people don't do it right, and then they conclude it must be bad
They don't have the ability to be self analytical, there is no way they could be wrong, therefore it must be the car that is wrong
Apparently some people like you and I, well, we are anomalies
